Ideas? What's cool to mount on rear window deck -brake light
Discussion in 'The Hokey Ass Message Board' started by fordstandard, Nov 2, 2011.
  1. My feelings exactly convert tails to led find something cool to install led's in for the 3rd.
    Better chance to be seen and save the car from some dumb*** rear-ending you .
    Firm believer in led lights
  2. Halfdozen
    Halfdozen
    I thought what he meant by "sub-standard" was sloppy, worn, not rebuilt. As far as there being "nothing wrong with the stock setup now", yeah it's rebuilt to like new condition, but just about every newer vehicle on the road in front of you weighs less and can stop in a much shorter distance with its power disc brakes. You're at a disadvantage, I'll bet you drive accordingly.
  3. tommyd
    tommyd
    from South Indy
    Many motorcycles have the brake light that pulses for a short time when first applied. It really grabs your attention. How about converting over to those?
  4. richie rebel
    richie rebel
    third brake light does look like street rods, but i like hotrods..........
  5. Hdonlybob
    Hdonlybob
    First I used an old German helmet with several bullet holes in it, and drilled another one in the middle of the back and mounted my third brake light in it. Was cool, but didn't really fit my car scheme...
    So next I took and old license plate holder with a '63 license plated in it and mounted this third brake lite to the top...
    I like it and it will remain in my '63 Biscayne...
    Cheers....
  6. hotrodchevy
    hotrodchevy
    im putting an led lightstrip simular to the ones sold to go under pickup tailgates along the lower rear panel on my 39 coupe (39 ford tailamps may as well not exist during daylight hours) hardly visible till lit then super bright stop,turn and running lamps.
  7. badshifter
    badshifter
    You may not realize it but every day modern cars with LED Halogen 3rd 4th 5th brakelights, ergonamically designed placed and computer enhanced get rear-ended. Putting a 3rd brake light on an old hot rod does virtually nothing. When it's time, you get hit. Period. In the mean time, most look really bad. In my unprofessional opinion you are more likely to get hit in a hot rod with a third brakelight as the drivers behind you will be so mesmerized by the awful looking red globe stuck on your car that they will be drawn to it like moths to a flame.
  8. 48FordFanatic
    48FordFanatic
    from Maine
  9. hotrodA
    hotrodA
    I snagged this one off the HAMB.:cool: Gl*** lense, just needs late model bulb.
  10. tommyd
    tommyd
    from South Indy
    Now THAT would be cool!
  11. ding ding ding winner
    use low or in the gap of the trunk seam
  12. bobbyd08
    bobbyd08
    from md
    X2 :)
    Bobbyd
  13. Tin Can
    Tin Can
    I have been thinking about putting a 58 chevy roof fent in my rear dash panel and modifying it to be a 3rd brake light...Maybe someday
  14. richie rebel
    richie rebel
    yah,put lights all the way across the back!!!!!!!!!!!!!
  15. 39 Ford
    39 Ford
    F--K tradition light the rear up and be safe. Use the brightest you can find. A guy I know has a row of leds across the underside of his rear body like they use on pickups. They are pretty much invisable unless lit up then WOW.
  16. RICH B
    RICH B
    I'm with badshifter on this one, the insurance lots are full of rear-ended late models.
    If people didn't see the lights on them, why do you think they will see the small tail lights and maybe a cutsey third brake light arrangement on a hot rod.
  17. so slightly off topic here. but i do ride my 05 sporty alot this summer i added what we will call a prisum to the headlight. i pulled out the bulb put the prisum in and put the bulb back in. It added other colors and made me stand out more. i have noticed that even in broad daylight people are not pulling out in front of me. i can only imagine that extra lights or brighter lights in the back will help.
  18. iammarvin
    iammarvin
    from Tulare, Ca
    Don't worry about the 3rd brake light, put a REALLY big spring on your bumper! Put a rat fink on the end of the spring...SHAZAM..Traditional!
  19. DE SOTO
    DE SOTO
    So,
    Is there some kinda Gaurante that if I Basterdize the Back of my Rod with a String of Christmas Tree Lights that I wont get Rear Ended ??
  20. Sure cant hurt, but anything to make them brighter would help.
  21. chevelle bob
    chevelle bob
    from Linton
    That is awesome, I will have to make one. Where did you find the "fink"?
  22. tedster
    tedster
    i don't care how worried I was about getting rear ended, I could not bring myself to hang LED lights all over it. Leave it in your driveway and sit in a lawn chair and look at it.
  23. OK this is way off topic but if you want to get folks attention and don't mind looking a little high tech they make an inertia switch for brake lights now. On hard braking it causes your brake lights to flash on and off onstead of just being a steady light.
    getting back to it what about a couple of hoola girls, with LEDs ****tered around in their skirts that would come on with the brake light and if you were on a bumpy road they would be wiggling all over the place.
    One I used to see at the shows was a cutom that they had put the scoop on the back of the roof, like on an old Olds. They filled the scoop with a third light.
  24. '51 Norm
    '51 Norm
    from colorado
    When this thread started I had just gotten the parts to put the third brake light into the roof of my '51 GMC. It isn't finished yet but you get the idea.
    The roof skin is a hood off of a '62 Ford Falcon, the lights are from a '99 Chevy Astro van. The light cost less than $10, the hood was somewhat more. Ok it was a lot more.
    The LEDs are clear when off and so are not obvious, they are pretty bright when they are on and so I'm hoping that the folks behind me get the idea.
  25. 36 ROKIT
    36 ROKIT
    Even with brighter bulbs and reflectors, the small tail lights on our '30s cars are not going
    to get the attention of distracted drivers. I'm thinking of something along the lines of portable/temporary that attaches with a magnet between the back window and trunk. Maybe a '40s/50s truck "STOP" accessory light. Simply unplug and remove upon arrival...
  26. My 6v '51 Pontiac lights are all but useless...you can bet there will be an additional light in the rear window when the 12v conversion is done...along with non traditional seat belts...
  27. Rod and Wheeler
    Rod and Wheeler
    from NOR CAL
    Hows about a Impala roof scoop.
  28. wojojo
    wojojo
    Or a Claymore mine on the back bumper covered with reflective tape. That'll wake up those idiots who were texting instead of paying attention.
  29. Deuce Daddy Don
    Deuce Daddy Don
    Eye level BRIGHT LED's from HONDA spoiler works for me!!!!
    PLUS LED bulbs in tailights!!----Don:D:D
  30. 2935ford
    2935ford
    On my '35 Slantback......I used a mid 80's Volvo 3rd eye. Fit like a glove and looked like it belonged there.:)
