I purchased what I'm told is an early '26 Ford T Ch***is ... The only identification on it I've found are in the pictures ... Any help would be greatly appreciated. I believe it's between 1919-1923 based on steering column mounted horn ****on and the leavers and their style but any info would be helpful. I want to pull as much info as possible so hopefully it's easier to get a ***le.
What you have is 1925 or older with a 1926 or 1927 big drum rear axle. The front spring mount will help date it, but that could have been swapped out years ago. What are your plans for it? Bob
I've seen two things in regards to the spring mount ... Something about a figure 8 or an Ella Fitzgerald????? No idea but saw that on another sight describing mounts to help date it
I know you asked for an iden***y, not an opinion.....but mine is free. A T ch***is is pretty flexible.....probably not the best foundation for a streetable hot rod.......I suggest you consider a Model A ch***is as a minimum, and they are not bridge girder strong, but are well ahead of a T ch***is. Best wishes with your build. Ray
You're fine ... Thank you ... It's helpful to hear opinions ... As of now I'm going to box brace the frame due to only running an i6 250
