Hot Rods Identify a T-10???
Discussion in 'The Hokey Ass Message Board' started by $100, Aug 10, 2023.
  1. $100
    $100
    Hello!
    I got a T-10 Saginaw for $5 and I plan on selling it as is.
    But can anyone help me identify which make/model this was manufactured for?
    Cast Mar 19, 1964
    Thank you in advance!
    PS can a transmission like this be rebuilt at home? Is that worth looking into? I'd love to learn more about doing something like that, for experience...
    Deuces likes this.
  2. Fordors
    Fordors
    Clean the area where I marked the photo, you will see a W, followed by another letter. The W stands for Warner Gear and the second letter for the month. The numbers are as follows - day of month, year and the shift it was produced.
    I rebuilt the one in my coupe, but that was literally decades ago, gears if needed could be hard to find today. Mine only needed a small parts kit, synchro rings and gaskets. They are not that hard to work on.
    Deuces, VANDENPLAS, alanp561 and 2 others like this.
  3. 427 sleeper
    427 sleeper
    If it was cast in '64, it was sold over the parts counter. GM was full steam ahead on the Muncie's by then. Looks like a wide ratio Chevy unit.
    alanp561 likes this.
  4. Black Panther
    Black Panther
    from SoCal
    It's not a T10 Saginaw...those are two entirely different transmissions. It's a Borg Warner T10..if its a 1964 trans, it could be out of a Studebaker or something else...
  5. squirrel
    it fits a Chevy, or other GM....so that does narrow it down
    The Magic Ratchet likes this.
  6. 427 sleeper
    427 sleeper
    Definately NOT from a Studebaker
    Deuces, Desoto291Hemi and alanp561 like this.
  7. Black Panther
    Black Panther
    from SoCal
    Oh? How can you tell? I found this on Ebay...looks close. Same case number on the one I'm showing. The extension housing has a different number..but that varies by year. Other sites say T10s were widely used by Studebaker..
  8. 427 sleeper
    427 sleeper
    The input shaft is TOTALLY wrong for a Stude.
  9. Black Panther
    Black Panther
    from SoCal
    They use 10 spline inputs..just like GM...the only thing I can see is that the Stude input shaft tip where it goes into the pilot bearing looks longer. Is that what you're talking about? I'm here to learn...not argue. I also try to give info when I can..
    427 sleeper likes this.
  10. 427 sleeper
    427 sleeper
    That's exactly what the difference is. It might be bigger in diameter, too.(The pilot) How's that for info???
  11. Black Panther
    Black Panther
    from SoCal
    Nice! You finally spilled the beans...lol
  12. 427 sleeper
    427 sleeper
    I didn't know that I had to give a blow by blow of the difference's. If you look at them side by side, the difference is obvious. Even if they're not side by side, the Stude input stick's out like a sore thumb compared to what we're used to looking at.
    lumpy 63 likes this.
  13. $100
    $100
    Ah, thanks - it says WD2443...
    Good to know it's not for a studebaker!
    I'll sell it as potentially GM
    If I take it apart, how do I diagnose whether a gear needs to be replaced? Just visual inspection?
    Is there any way to test if it's good without having to put it in a car?
    Thank you everybody!
  14. squirrel
    Visual inspection will tell you a lot if you know what to look for. Usually worn synchronizers cause problems, but judging if the wear will or will not cause rough shifting takes some experience. And part of the synchronizers is the small teeth on each gear, that mesh with the synchro sleeve. The main gear teeth usually aren't the problem.
  15. HEATHEN
    HEATHEN
    from SIDNEY, NY
    ...or it could be from a Buick. I had a '65 Skylark 300/4 speed car that came with a T-10.
  16. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Yeah, my cousin once bought a T10 at a swap meet for cheap without paying much attention to the input shaft, only to find out after the fact that it was from a Studebaker; however, it all worked out when he sold it to a Studebaker guy for a decent profit.
  17. ssaza25
    ssaza25
    from arizona
    Same here, bought one thinking it was a chevy, turned out as a Studebaker- Still have it, anyone needing ine?
    Boggus Deal likes this.
  18. PackardV8
    PackardV8
    The '57-'65 T10s were OEM in Chevy, Pontiac, Ford, Mopar, Studebaker, Shelby Cobra, AMC, et al.
    Big block and small block Fords had different input shafts.
    Studebaker used both the Chevrolet and Ford bolt patterns and close and wide ratio ge****ts.
    There are six different input shafts, three different bolt patterns, four different tailshaft housings and three different gear ratio sets.
    During the mid-'60s, when GM was developing the Saginaw and Muncie, Ford was developing the Top Loader and Mopar was developing the A833, there was not enough of the new design production to go around, so some cars were built with the T10s, some got the new proprietary trannies.
    That's the easy part; when the Super T10 comes in too many variations to list.
    jack vines
  19. treb11
    treb11
    Can you just change the input shaft to GM style ?
  20. studebakerjoe
    studebakerjoe
    @ssaza25 too bad you're all the way in Arizona.
  21. ssaza25
    ssaza25
    from arizona
    Shipping would be a deal killer.
  22. lumpy 63
    lumpy 63
    Ok I'm gunna be the old guy who say's " GET OFF MY LAWN!" We have a new guy , no introduction , wanting to know what something is and what its worth ...
    Hollywood-East, 19Eddy30, X38 and 2 others like this.
  23. X38
    X38
    I hope everyone gets their cut on the profit.
    lumpy 63 and 19Eddy30 like this.
  24. Russ B
    Russ B
    Around 1966, I bought a Studebaker T-10. It fit my ‘57 with small journal 327 just fine with only turning down the diameter of the input shaft holder, that carried the throw out bearing. It is so long ago, that I might have replaced the input shaft for a Chevy piece. Regardless, it was not a difficult job for a twenty year old kid. Hurst had a shifter for use with the T-10 in a 55-57 Chevy.
    Deuces and Hollywood-East like this.
  25. X-cpe
    X-cpe
    We had an AMC T-10 in our stock car. Bolted right up to the SBC after we bored out the pilot bearing.
    Deuces and Desoto291Hemi like this.
  26. Boggus Deal
    Boggus Deal
    Possibly…I believe a lot of the internals of a Stude T-10 are the same as Fords. PM me, please!
