Hot Rods Identify Isky cam
Discussion in 'The Hokey Ass Message Board' started by mark hogan, Dec 6, 2024.
  1. mark hogan
    mark hogan
    I’m having a rough time figuring out what older cam this is any ideas? Thanks IMG_4207.jpeg IMG_4205.jpeg IMG_4207.jpeg
  2. Budget36
    Budget36
    Is that the manufacturer? I can’t help with ID, just never heard of Elske. Does look like a Ford FH V8 cam.
    mark hogan and Unkl Ian like this.
  3. Budget36
    Budget36
    Oh, Isky, may want to edit your ***le:)
    I think you can still contact them as well.
    mark hogan likes this.
  4. sdluck
    sdluck
  5. mark hogan
    mark hogan
    Yeah I’ll call them. Just had my sights on a seasoned Flathead gear head to give me the grind of this particular cam. Cold stamps and double stamp is impossible for me to read.if it had been a 302-289-327-350-427-396-351- I’d have an idea myself. But new to old school flatheads I’m in the 101 cl*** of visual and research Thanks fellow rodders.
  6. mark hogan
    mark hogan
    Isky is the correct abbreviation. Yes this pictures from a 1948 flathead just don’t have any areas to match what I’m seeing on cam nose. Like to know the specs of the beast. Thanks
  7. Ericnova72
    Ericnova72
    from Michigan
    If you've got a dial indicator and magnetic base handy, you can just degree it and find out exactly what it measures.
    Reverse engineering a cam card in the process.
    If you need a degree wheel, Tavia has a link for a printable degree wheel. You can print one out and then just glue it to any cheap round and flat object like a pie tin or plastic Frisbee or picnic serving plate that you can punch a hole through the center for a bolt hole.
    Custom bend up a coat hanger wire pointer and off you go, get it done.
    Tavia Performance Products Downloadable Degree Wheel
    Budget36 likes this.
  8. mark hogan
    mark hogan
    Thanks but I was under the gun during build due to space. Was told data was in the works? It did not happen. All I have is the old photos. Just like to have the info for performance & dial-in IMG_5225.jpeg IMG_5225.jpeg
  9. Ericnova72
    Ericnova72
    from Michigan
    Right-O
    Nice ride, I like it! Cool
