Technical Identify Mallory distributor
Discussion in 'The Hokey Ass Message Board' started by BJR, Aug 13, 2022.
  1. BJR
    BJR
    I have a Mallory Model ZC Type 301A. It has instructions for running in the points dated 1952, a 2 piece cap with the number 24004 on the bottom piece and 24005 on the top part. A rubber piece goes between the bakelite parts with the number 24902 on it. It appears to be NOS. What does it fit?
  2. SS327
    SS327
    An engine?
    Sorry, I couldn’t help myself!
    Texas Webb likes this.
  3. You sure that's not ZC 301? Guessing Y-block.
    BJR and wraymen like this.
  4. BJR
    BJR
    No it's 301 A
  5. I mean ZC instead of 7C.
    BJR likes this.
  6. BJR
    BJR
    Yes it is ZC it is stamped low and into the black, didn't see the bottom of the Z.
  7. wraymen
    wraymen
    Mercury Y block= 301
    BJR likes this.
  8. squirrel
  9. wraymen
    wraymen
    I believe the ZC has both mech. and vac. advance, YC mech. only.
    BJR likes this.
  10. wraymen
    wraymen
    Budget36, BJR and squirrel like this.
  11. Carter
    Carter
    301 shows to fit 1954 Ford/Mercury 250/256 8cyl.
    BJR likes this.
  12. BJR
    BJR
    The JC Whitney catalog lists the 301A as 54 Merc, different number for Ford. This one doesn't have a vacuum advance on it and doesn't look like there is a place to put one.
    Carter likes this.
  13. Fordors
    Fordors
    The ZC Mallory’s have a vacuum brake, as was used on flathead Fords. With low vacuum a leather pad rubbed on the point plate to retard the advance. It will not be a regular appearing vacuum canister.
    Look for a small welch plug in the distributor body, or later distributors used a sheet metal cover held in place by two screws, (10-32’s?) behind that cover is a spring , piston and the leather pad. A tube may be on that cover for the vacuum line or sometimes Mallory drilled and tapped the casting with 1/8” NPT for a fitting.
  14. BJR
    BJR
    OK this has the vacuum brake, it has the cover with 2 screws and a spring behind it. And there is a NPT plug in there for the vacuum line. Thanks everyone, now to find someone who needs it.
  15. briz
    briz
    I tried to find a replacement 2 piece cap and the rubber seal that fits between the pieces for several years for the Mallory dizzy on my flathead. No one made replacements as of about 2010- 2014. Maybe someone does now?
  16. tubman
    tubman
    Watch eBay for a while. Every once in a while, some undesirable model will come up for sale cheap (usually RB Chryslers and Pontiacs). The caps fit all of the distributors (but you need the matching rotor). Buy one for parts.
  17. plymouth1951
    plymouth1951
  18. plymouth1951
    plymouth1951
    If its a six cylinder it could fit vintage flathead mopar..include a pic and we can better help . I collect old plymouth flathead distributors if you are selling .
  19. plymouth1951
    plymouth1951
    My contact info is mike schmitt 8183709168 for call or text
