Technical Identify model B engine?
Discussion in 'The Hokey Ass Message Board' started by Fjant, May 23, 2023.
  1. Fjant
    Fjant
    from Sweden
    Hi! I’m looking to buy an engine. Suposebly a model B.
    I have searched online but can’t really figure out the engine vin. Can you help me please
    it looks like this.
    ☆SB☆123☆ F
    O Z 74
  2. Pete Eastwood
    Pete Eastwood
    from california
    If it has a provision on the right side for a mechanical fuel pump, it's a "B"
    No fuel pump it's a "A"
    winduptoy, LOU WELLS and 51 mercules like this.
  3. Fjant
    Fjant
    from Sweden
    I suppse this is the fuelpump?
    51 mercules likes this.
  4. nosnhojguy
    nosnhojguy
  5. '29 Gizmo
    '29 Gizmo
    from UK
    Model A has an oil return tube on the right side of the block behind the carb. Model B does not. Model A top hose to the radiator comes from the head. On the B they are from the water pump but heads are interchangeable
    winduptoy and Fjant like this.
  6. Fjant
    Fjant
    from Sweden
    Is the short number on the engine tag the same as the vin number on the car? It seems so short. Can you tell the year of the engine by the number?
  7. winduptoy
    winduptoy
    B engine didn't have a serial number stamped on the pad on the block...it was on the bell housing
    That doesn't mean that someone didn't stamp one there at some time especially if it was installed in an earlier car
    and you are in Sweden so anything I know probably doesn't count anyway
    The number you posted looks made up and follows no convention I am familiar with and a vin number didn't exist in the years B engines were made. There may be a casting number that would help you establish the year of manufacture but all parts for B engines across all years are the same...I guess it depends on what you are trying to achieve...but we are back to everything I know doesn't count anyway
    Good luck
  8. Budget36
    Budget36
    Regardless of VIN v SN, I think above it was confirmed as a B engine. I can’t imagine (other than being curious) why the year would matter?
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    As I understand it, the earlier B engines didn't have a counterweighted crankshaft.
    ClarkH and Budget36 like this.
  10. Budget36
    Budget36
    I see. I guess year may be of a concern then.
  11. '29 Gizmo
    '29 Gizmo
    from UK
    Worth checking if its a diamond block. They were not serial number stamped in the usual format, or at all in some cases. https://www.fordgarage.com/pages/diamondblock.htm
    There were several cranks in B blocks, from no counterweights, to add-on weights to forged integral counterweights.
    ClarkH and winduptoy like this.
  12. Fjant
    Fjant
    from Sweden
    okey. Tank you so much!
    winduptoy likes this.
  13. Fjant
    Fjant
    from Sweden
    Okey! I got the iden***y on my model A from my engine since it was hard to identify on the frame. Was thinking I might be able to get the identifikation for another project that the engine would be in.
  14. big duece
    big duece
    from kansas
    Weren't the crank mains larger on a B compared to the "A"s?
  15. winduptoy
    winduptoy
    yes and rods too
    the other advantage to the B is that the A is all gravity oiling to the mains/cam and the B is semi pressurized and can be pressurized pretty easy with some modifications
    ClarkH, Fjant and big duece like this.
