Technical Identify the Differential
Discussion in 'Traditional Hot Rods' started by 59 Fleetside, May 18, 2015.
  1. 59 Fleetside
    59 Fleetside
    This differential is in my 59 Chevy Apache. I'm pretty sure it's not the original.
    It was in the truck when I bought it.
    I know it's a GM rear but that's all I know.
    It has drum brakes and I want to do a disc conversion.
    How can I identify the donor vehicle it came out of ?
  2. the-rodster
    the-rodster
    Looks like a factory four-link.
    What's the bolt pattern?
    If it's a car bolt pattern, possibly G-body.
    If it's truck bolt pattern, possibly full size GM like Buick or Caddy.
    Rich
  3. 59 Fleetside
    59 Fleetside
    5 lugs- I'm not sure if car or truck
  4. Rocky
    Rocky
    Classified Editor
    It won't be a truck because they had different mounting. Will be a GM car axle that came with rear coil springs.
  5. Larry T
    Larry T
    There are a couple of different GM 10 bolt rearends it could be, or it could be a 12 bolt. Can you get a picture of the rear cover?
  6. Larry T
    Larry T
  7. the-rodster
    the-rodster
    It could have truck bolt pattern, 5 on 5, if it's from a full size caddy.
    Rich
  8. the-rodster
    the-rodster
    soooooo...
    1. Determine lug pattern.
    2. Get good pic of back cover.
    3. Measure width, backing plate to backing plate.
    Rich
  9. Larry T
    Larry T
    If you're wanting disc brakes, I'd look at some off Firebirds. Should be a pretty simple swap.
  10. squirrel
    If you're looking to do a disk brake conversion, I'd ask "why"? Not much braking action going on with the rear brakes in an old pickup truck, since there's hardly any weight on the rear wheels when you're stopping hard.
    btw the size of the rear brakes it has now will help figure out what the rear is out of. Mostly the full size cars used 11" brakes, midsize cars used 9.5" brakes.
  11. Hotrodbuilderny
    Hotrodbuilderny
    Looks like a 10 bolt GM 8.5 or 8.2 65 to at least 74, and disc brake kits are the same
  12. belair
    belair
    What squirrel said.
  13. 59 Fleetside
    59 Fleetside
    A very belated thanks to all who responded. Squirrel's point resonates with me. The truck stops just fine with rear drums and front disks
  14. fergusonic
    fergusonic
    from Kokomo, In
    From the picture it appears that the right side has a little Toe In !
  15. Is there a serial number on it? Google it and see what comes up.
