Technical Identify These Mystery Ford Backing Plates???
Discussion in 'Traditional Hot Rods' started by vintagehotrods, Mar 26, 2023.
  1. vintagehotrods
    vintagehotrods
    A friend of mine recently picked up these early Ford Lockheed style hydraulic backing plates. He's been working with this old Ford stuff for 50 years and has never seen another set like it. What makes them different than the regular '39 to '41 hydraulic backing plates is that the the bottom halves are ventilated. They have Factory Ford script stamped on them and they look like factory stampings, not modified hydraulic backing plates. They are for standard 12" drums and have grooved brake shoes. What were they used on and what years were they made? Have at it guys!
    Deuces likes this.
  2. panheadguy
    panheadguy
    from S.E. WI
    I have seen backing plates opened up like that for racing, but as you say these look to be factory made. I've never seen any like this before.
    Deuces likes this.
  3. '29 Gizmo
    '29 Gizmo
    from UK
    Based on 46-48 but with back plates trimmed maybe
    RAK, Deuces and woodscaper like this.
  4. woodscaper
    woodscaper
    Looks like they were trimmed on either side of the wheel cylinder too, lost a lot of rigidity there.
    Deuces likes this.
  5. Racing use is to obvious :D . How about something strange like clearance issues or such for a railroad car :rolleyes:o_O or vintage fork-lift or airport /plane tow vehicle .
  6. hotcoupe
    hotcoupe
    I'd have to say, nicely modified by a stock car racer. In my younger life I had similar ventilated brake shoes on a '55 Chevy with a big block that I used to drive fast and hard.
    Tom
    VANDENPLAS and Deuces like this.
  7. pprather
    pprather
    How about a tractor, or some other industrial use?
    Deuces likes this.
  8. One thing for sure is driving through deep water the water will run out just as fast as it came in :eek: , won,t have to pump much :rolleyes:.
    Deuces likes this.
  9. dirt car
    dirt car
    from nebraska
    I'm using a pair of aftermarket skeleton backers on my avatar, not sure if your Ford examples were modified or actual Ford components, & I agree a bit thin in the support area of the wheel cylinder, in fact one of my aftermarkets have additional support in that area undoubtably intended for the right front use in circle track &/or possibly any of the four corners in road race applications. Well done if home brewed for sure, however appear to be the first generation with the lower adjustments.
    Deuces and seb fontana like this.
  10. alchemy
    alchemy
    I agree that they are modified, not Ford produced.
    Deuces likes this.
  11. vintagehotrods
    vintagehotrods
    You would think that, but what's odd is you can see the cutouts are stamped out by a stamping die by the cut on the edges, and because I don't see any evidence of a cut and a smooth ground edge there. After seeing them up close in person. I think they are a factory piece. Either way, I think they are a cool looking piece. It will be interesting to see how they perform in regard to the missing pieces and if there is a noticeable loss of rigidity. They may be used on a flathead powered '34 roadster.
    I checked the pics of the brakes on the 8N Ford tractors that were sold at that time and they aren't even close.
    I also wondered if they might me a hydraulic version of the mechanical "Rocky Mountain" brakes, but no one has heard of anything like that either.
  12. Outback
    Outback
    from NE Vic, Oz
    Have you tried The Ford Barn?
    Deuces likes this.
  13. vintagehotrods
    vintagehotrods
    I tried, but for some reason I couldn't get the pictures to post. I'll try again.
    Deuces likes this.
  14. vintagehotrods
    vintagehotrods
    These are actually the '39-'42 versions, because the bottom pivots are adjustable, not fixed like the '46-'48 versions.
    '29 Gizmo and Deuces like this.
  15. vintagehotrods
    vintagehotrods
    They did a really good job on modifying them because there's no sign of them being cut or ground that I can see, but the consensus is that they are modified originals so I'll go with that.
    Outback likes this.
