Identify this front suspension
Discussion in 'The Hokey Ass Message Board' started by Whiplash, May 26, 2007.
  1. Whiplash
    Whiplash
    its on my 37 pontiac coupe
  2. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    where is it grafted in?
  3. Wesley
    Wesley
    that looks like it came off of a 50s-60s british sports car, think Jag, Triumph, MG, Austin Healy. I could be wrong, but it looks strangely familiar. The lower control arms and upper knee action shocks/control arms look alot like MG midget, only bigger.
  4. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    I agree- Buick mad a set up like that, as did Packard.
    but neither one was "exactly" that ***y.
  5. classicfins
    classicfins
  6. brandon
    brandon
    for some reason i am thinking 49-54 chev.....or early vette...??? which are the same....i am going by the spindles....brandon:D
  7. Andy
    Andy
    Kinda looks like 50 Olds. GM for sure
  8. mazdaslam
    mazdaslam
    Uhhhh..........thats 37 Pontiac suspension.........with a hacked on steering rack.
  9. pasadenahotrod
    pasadenahotrod
    from Texas
    Isn't that the original suspension for that car? It looks like the one under a 36 Olds a friend of mine owns.
    I see nothing non-stock except that funky rack and pinion steering??
  10. Whiplash
    Whiplash
    it could be the original suspension, it is cast with GM on it.
  11. ProEnfo
    ProEnfo
    from Motown
    ..stock
    CC
  12. Wesley
    Wesley
    my only defense for not knowing it was the stock stuff is that I have never worked on early GM cars that still had the stock suspension in it. I only get the cars that someone did a hack job on and want me to fix it.
  13. LUX BLUE
    LUX BLUE
    Alliance Vendor
    from AUSTIN,TX
    That's why I was asking where it was grafted.
    but yep, I can honestly say I have not much screwed around with a late 30's pontiac (or late 30's anything, for that matter) that had not been screwed with somewhere along the line.
    on to the next question-
    does it have a disc brake conversion on it?
  14. fab32
    fab32
    Looks exactly like the stock '36 Olds frontend that a friend has.
    Frank
  15. knotheads
    knotheads
    looks like a stock pontiac suspension with a disc brake conversion
  16. FoMoCoPower
    FoMoCoPower
    the calipers are mounted backwards
  17. olskool37
    olskool37
    Yup.. just confirming the stock stuff... I got a '37 Pontiac slantback sedan. if you want lowering springs for the front Eaton Springs gottem' they used my stockers to get the spring rate data, and sent me a set.
    Just checking... would you know anyone with extra chrome for the hood laying around. got anyother questions, or want reference pics lemme know, I know of 2 other local boys with '37 Poncho
    Email olskool37@aol.com
    http://onfinite.com/libraries/879423/album/540/405/82c.jpg
    http://onfinite.com/libraries/1181506/album/540/405/61b.jpg
      56.8 KB
  18. Whiplash
    Whiplash
    Yes it was the disc brakes and the goofy steering rack plus the fact that it was chromed years ago that lead me to beleive that it was not stock. Thanks for all your help! I am still looking for a drivers door for this 37-38 pontiac coupe
  19. scottybaccus
    scottybaccus
    Is that a hydro shock built into the upper control arm mount?
  20. 55 dude
    55 dude
    whatever it is it looks dangerous too me! better get the fire wrench out and remove it.
  21. olskool37
    olskool37
    Yeah, a knee action shock of sorts, GM did this quite a bit in the 30's, as well did other makes. Im lookiing into the potential of adding bags that would replace the coils... any thoughts on this? my main concern being if the bag blew... theres no other secondary support
  22. scottybaccus
    scottybaccus
    Bags would be easy enough. You just need to ensure that nothing touches them through out the suspensions range of motion. If you lost pressure, it would just sit down on that bump stop. Pull the coils and set it down to see what you have to work with. If you can get bushings, etc. to refresh that set up, I'd run it. Even the shocks.
