Identify this low-mount SBC alt bracket?
Discussion in 'The Hokey Ass Message Board' started by sixdogs, Jul 28, 2009.
  1. sixdogs
    sixdogs
    from C
    I have been trying to identify thls low mount SBC driver's side alt mount short pump. It is the tightest one I have seen and since I don't have a lot of space it would work for me. I have searched and searched and cannot see one like it butI think it's an off-t******lf bracket . What seems to make it different is the aparent tightening bolt between the brackets. The tightness to the crank and lowness is important.
    As an alternate I could use a p*** side high mount that is tight to the valve cover and in close to the engine. Any ideas helpful as there are dozens of different brakcets out there and you have to almost see them to understand
    Has anyone seen a bracket like this or maybe identify it? Thanks.
  2. john walker
    john walker
    how are your fab skills? easy enough to make some brackets that fit your needs.
  3. Spity
    Spity
  4. pasadenahotrod
    pasadenahotrod
    from Texas
    I have one of those multi-piece brackets you illustrated. Got it from a friend years. Wouldn't mind knowing the maker either.
  5. sixdogs
    sixdogs
    from C
    These are nice but not tight enough. In my photo you can see they hug the crank pully.
    Fab skills good but this is too much time for right now. Got to drive it and this would be a lot of time for small gain if I can buy one cheap enough.
  6. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    Alan Grove makes a really nice low mount alt. bracket. Gary
  7. Spity
    Spity
    You cant get the alternator any closer than the bracket I posted.
    Cheap, fast, and right; Pick two.
  8. MedicCustoms
    MedicCustoms
    The on above bolts to the same two holes on block. If one will fit so will the other one . The one in your first pic looks like a RPC they are sold at Barnetts Performance here in Ga... But I've run both of them this is my .02
  9. spinout
    spinout
    from Dallas, TX
    The one in your pic is Total Performance I think. Speedway too.
  10. rusty1
    rusty1
    Speedway motors has em...
  11. slddnmatt
    slddnmatt
    speed way...for a short water pump. if you have a long pump you have to make new spacers
  12. Beef Stew
    Beef Stew
    from So Cal
    only problem i see with the first one is poor belt wrap on the crank pulley. the alternator is too low and pulling the belt off the pulley.
  13. frank dog
    frank dog
  14. sixdogs
    sixdogs
    from C
    Thank you all very much. The black mount above is indeed the tightest one made. There are actully a number of different low and lower mounts made--plus what one can fabricate--but I don't think they get any tighter or less expensive than this.
    Speedway, and others have a "lower" mount similar to this and a "low" mount that is not quite as low. With the lower one-similar to the bottom photo above, you can fit a standard alternator in a space as wide as it is plus maybe 1/8"-3/16" clearance. Thanks guys, I spent a lot of time trying to figue this out and it's now solved in a couple minutes. Happy motoring.
  15. oj
    oj
    I think the 2 piece w/spacers in the 1st set of pics is available from TransDapt, part #8990 and works with a short water pump. Alan Grove makes nice ones too.
    I wish the catalogs would come out and say which altenator their brackets will work with, easy to get a trick little brackets and then find it'll only work with a $250 altenator the size of a coffee cup.
  16. Rot'nRodder
    Rot'nRodder
    I'de say that's prolly an Alan Grove bracket. They make nice stuff....it's not that China ****.
  17. panhead_pete
    panhead_pete
    Did you guys by chance have an eBay name for the guy selling those?
  18. brandon
    brandon
    that bracket above would have been a problem solver on the last stocker nova race car i messed with. the normal "low mount" always seems to put the alternator into the crossmember or the steering box. will have to keep that link for referrence. thanks brandon :D
  19. 34toddster
    34toddster
    from Missouri
    Alan Grove, nice stuff made in Kansas by people that even speak english! I buy ALL my brackets from them Never had a problem one!
  20. BULLITT65
    BULLITT65
    from Indiana
    summit sells these as well but in machined aluminum
  21. Dane
    Dane
    from Soquel, CA
