Identify this tool
Discussion in 'The Hokey Ass Message Board' started by POLYFRIED 35, Jul 4, 2014.
  1. POLYFRIED 35
    POLYFRIED 35
  2. indyjps
    indyjps
    Looks like an oil pump driveshaft for priming an engine, how long is the shaft/shank?
  3. tfeverfred
    tfeverfred
    X6 ....... times.:D
  4. POLYFRIED 35
    POLYFRIED 35
    Ok I don't know why all the post but maybe they will ignore the rest until I figure out how to remove them. Do you mean the depth of the notch?
  5. POLYFRIED 35
    POLYFRIED 35
    There is no shaft just a handle like a screwdriver.
  6. seb fontana
    seb fontana
    from ct
    Sorta looks like the tool for putting the brake shoe springs together..
    jimcolwell likes this.
  7. POLYFRIED 35
    POLYFRIED 35
    It's pretty close ... May be.
  8. Hnstray
    Hnstray
    from Quincy, IL
    You can delete your excess posts by going to each of them, click on 'edit', then, 'delete'
  9. If not for brake shoe springs, something similar. There were valve spring keepers that were a pin that slipped through a cross hole in the valve stem. I remember them in an old Fairbanks-Morse engine my dad had way back.
  10. POLYFRIED 35
    POLYFRIED 35
    Thanks for the tip... I'm using the HAMB AP on my phone and that does not seem to be an option. It gives me the option to go to web view but once there I see no option to delete just edit the title and text.
  11. I have seen one of those many years ago but cant recall what it was for. JW
  12. I seem to remember a tool like that to open petcocks.
  13. fleabag
    fleabag
    Can't tell by the pic but when I worked for Ford making lamps we seated a lot of twist clips and adjusters with tools that look close to that
  14. POLYFRIED 35
    POLYFRIED 35
  15. golftech
    golftech
    It's for brake springs, I use one almost every day.
  16. POLYFRIED 35
    POLYFRIED 35
    Thanks for the input guys. I knew once the smoke cleared from the HAMB AP posting this a bagillion times someone would know.
    Looks like it's a brake spring tool.
