Technical Identify this trans
Discussion in 'The Hokey Ass Message Board' started by deto, Oct 19, 2014.
  1. deto
    deto
    Hey guys. I'm new to 4 speeds and I wanted to know if this is a T10 or a Muncie. Sorry for the ****py pic but its the best I can do. The guy selling it is cleaning out his grandpas garage and didn't offer any more info than he thinks its out of a first gen camaro.
  2. squirrel
    saginaw. Because the reverse lever is on the side cover, not the tail h ousing
  3. deto
    deto
    Is this model robust enough to handle a hot SBC in a 3200 lb car? Would it have been available prior to 1964?
  4. 333 Half Evil
    333 Half Evil
    I believe squirrel is right. Depending on what the hot SBC really is and how you plan on driving, it will handle it's fair share. I've run saginaws in stock cars with 500+ hp as well a several off topic drag cars running high 11's low 12's and did not have many problems at all. Yes, I've broke some, but I've also broke muncies and borg-warners too. The only stock gm 4 speed I've not broken yet was the super t-10's, they are quite durable!!!
  5. Seriously now, that all depends on what you plan on doing with the car and how you drive it.
    I think the Saginaw 4 speed came out in the mid 60's
    Google is your friend, my friend
  6. deto
    deto
    327, 10:1, solid roller can, 510 lift. I think I have an intake picked, low rise dual quad. I think 380hp is conservative. I would like to be able to drive it fairly hard. I guess I will know if/when I blow it up...
  7. squirrel
    It's probably going to last at least as long as the "correct" BW T-10, and will probably cost a bunch less. Don't tell anyone it's a Saginaw...odds are, like you, they won't know just by looking at it.
    as far as durability..if you lift your foot off the gas for the 1-2 shift, it will last a long time, if it's in good condition to start with.
  8. onetrickpony
    onetrickpony
    from Texas
    I ran a Saginaw for a couple of years behind a warmed over 283 in a '66 C10. On narrow street tires, it did fine. I sold it to a guy who put a set of sticky tires on it and blew the trans on the first burnout.
    Your mileage may vary.
  9. deto
    deto
    Thanks squirrel
  10. 38Chevy454
    38Chevy454
    As Squirrel suggested, speed shifting will contribute to a quick end. Saginaw were used behind mild small blocks, so it has some strength capacity. The exact internal trans gear ratio is the indicator of the torque capacity, generally higher number first gear ratio is weaker. Look for the number of grooves on input shaft and then compare that to search for the values.
  11. Shaggy
    Shaggy
    from Sultan, WA
    That's what many came in, I'll add looking that it's a close ratio because of the lines on the imput shaft
  12. There's a good reason why they put them in Vegas!
    Transmissions (and rear ends) don't necessarily break in the middle of a gear sequence, but almost always on a power shift or starting line launch.
    There's a lot that you can get away as far as light duty stuff, if drive the car prudently.
  13. deto
    deto
    I'm picking up a freshly rebuilt Muncie M20 tomorrow... No need to bother with a Saginaw naw
