Projects Identify this truck
Discussion in 'The Hokey Ass Message Board' started by 81deeds, Jan 19, 2014.
  1. 81deeds
    81deeds
    Year anyone??
    Thanks derek
  2. bscc50
    bscc50
    from n.e.
  3. 81deeds
    81deeds
    Im looking for ****** an pedals to go behind my 53 merc motor in my model a.....this truck is available to me for parts...does anyone know if this will work?
  4. 65standard
    65standard
    maybe 1941 Ford One Ton because of the hood moldings and can headlamps
  5. 81deeds
    81deeds
    One more pic...to identify
  6. 81deeds
    81deeds
    Upper rad hoses go to the head built in...no thermo housing
  7. adam401
    adam401
    Grab the gas pedal and clutch brake pedal ***embly and engine if it's not ****ed. Leave the ****** behind its no good for your a.if it's cheap, strip all the dash stuff but it's not something I'd buy for a parts truck unless you can get it priced at s****
  8. 81deeds
    81deeds
    Its all free...thanks man
  9. 57 Fargo
    57 Fargo
    Yep '41 one ton express, I just learned that because I inherited one with my new property and it was identified here on the hamb on fri!
  10. 81deeds
    81deeds
    What year you think adam? Upper hoses molded directly to heads an distrib is crab cap directly behind belts horizontel
  11. adam401
    adam401
    40 or 41 but I don't know how to tell the difference by eye balling it. but that's the only 2 options. The few 42s made had headlights in fenders and its not a 39
  12. ChefMike
    ChefMike
    its not a 47 ford looks like a 41
  13. '40 and '41 big trucks are essentially the same. Way to tell them apart is narrow chrome on'40 hood and grille center, '41 has wide hood and grille chrome. Ford emblems on '40 hood sides are same script emblems as '39 Deluxe and '40 cars. '41 has the rectangular Ford emblems.
  14. 57 Fargo
    57 Fargo
    I could use the grill and headlights....
  15. 81deeds
    81deeds
    Thanks 57
  16. 81deeds
    81deeds
    I will see if i can get exterior parts for you...i think owner is trying to keep outer shell for eye candy...i was offered mechanical stuff...let u know though tommorow
