identify this?wtf is it?
Discussion in 'The Hokey Ass Message Board' started by milltownrodz, Oct 17, 2009.
  1. milltownrodz
    milltownrodz
    i picked this holley mag/dist the other day?what is it for?anybody know/???????ideas?tractor?it has oil inlet outlets as well??????
  2. beemryder
    beemryder
    No doubt I will be tagged as being a ass, but the little tag with the numbers on it that we can't read from the photo are probably a good point to start from.
    You have a model number and a part number. Holley is still in business...
    The fittings are probably for oil lines?
  3. milltownrodz
    milltownrodz
    yes butt no idea they say?
  4. What first popped into my mind was a fuel pump, but I have never seen one like that.
  5. Mr48chev
    It looks like it might be a mag off a farm Tractor engine or industrial engine.
  6. 3in1
    3in1
    from nevada tx
    The safety wire could be air craft or military ,but my best guess is an ice cream blender less the prop .... or im just hungry .
  7. Midnight 50
    Midnight 50
    Says clearly on the side:
    Part No: *-719
    Model: 1255
    Eng. Mfg. No: 48312
    Holley Carb Co.
    To me that's all you need to know to find the info. (* means can't read the first number)
  8. Bullrack
    Bullrack
    from Louisiana
    How many cylinders? What rotation direction?
  9. RichFox
    RichFox
    Is that a hex on the end of the shaft. Holley made some distributers for Ford
  10. R Pope
    R Pope
    Those aren't oil fittings, they are vacuum ports for a vacuum governor. They go to a diaphragm on the carb. There's a centrifugal setup in the bottom part of the dist. Common on big gas engined trucks.
  11. milltownrodz
    milltownrodz
    6 cyl clockwise i belive?
  12. milltownrodz
    milltownrodz
    its actualy a gear drive..part of the shaft tho?
  13. oldspwr
    oldspwr
    I have a '58 International V220 dump truck with a 549 International gas job. The 549 is a V8, but it does have a Holley distributor very similar to yours. I'll check the part numbers later.
    Governors' were typically mech. wired so that drivers could not tamper with them and over run the motor.
  14. milltownrodz
    milltownrodz
