Technical Identifying 4 jet
Discussion in 'The Hokey Ass Message Board' started by rocsas, Jan 9, 2019.
  1. rocsas
    rocsas
    from colorado
    I'm trying to figure out which model 4 jet I have I bough off a guy, it looks complete but is missing the tag with the part number, he said he thinks it is a Buick carb. It is an iron base and I think It has an aftermarket electric choke, any advice will help thank you
    IMG_20190109_113118.jpg IMG_20190109_113110.jpg IMG_20190109_113105.jpg IMG_20190109_113100.jpg
  2. Bleach
    Bleach
  3. HOTRODPRIMER
    HOTRODPRIMER
    Isn't a G4 a marine carburetor?HRP
    deathrowdave likes this.
  4. Terrible80
    Terrible80
    Tman, Saxman, Dago 88 and 4 others like this.
  5. ken1949car
    ken1949car
    from chicago
    Hey, when you view the carb from the top, choke on the left side, look closely at the right rear of the air horn near the screw at the corner. The top will sometimes have the number etched into the carb. Clean the area carfully with lacquer thinner or carb cleaner. I have rebuilt several and the model # is usually there. If not, you will have to match gaskets from Mike's carb web site. Good luck.
    clunker and KoolKat-57 like this.
  6. It's a Chevy carb. Some kind of power pack deal. Could be a '60 type or a 64-66 series. You might have to measure the venturis to find out for sure.
    Let's see the primary venturi cluster (booster).
    Note: later model has a 1.437 throttle plates. Look like one from here.
  7. 2935ford
    2935ford
    I have one very similar.
    Rochester 4G.
    I'm trying to find an air cleaner to fit it. Due to the rise behind the fuel inlet, aftermarket chromie air cleaners won't clear it.
  8. carbking
    carbking
    Looks like a "Frankencarb" to me; part Chevy, part Buick.
    Jon.
    egads likes this.
  9. You're right, Jon. Didn't notice at first, but the top doesn't have the four Chevy type bowl vents.
  10. DDDenny
    Beats me!
    My 57 Chevy had one...........for about a day, replaced it with a Holley, that was 1971.
    Truckdoctor Andy likes this.
  11. carbking
    carbking
    The 4G series were really good carbs. There were a few that were rated 700 CFM. Really a great "street sleeper" for the folks that took the time to figure out how they work. Once on an engine, difficult to tell the size.
    Jon.
    Tman and saltracer219 like this.
  12. rocsas
    rocsas
    from colorado
    i got it apart and cleaned but could not find any number stamped, also it was rebuilt with incorrect gaskets and accelerator pump so this should be a fun one to figure out :rolleyes:
    I agree it looked like 2 different carbs made into one after digging into it
  13. some had larger secondairy throttle's. wouldn't work on a 22o Hp chevt intake. but worked great on a 300 Hp 327 manifold. They are good reliable carbs.
  14. PackardV8
    PackardV8
    Yes, they're good, reliable carbs; good enough to be used on 340hp 409"s right up to the end of production.
    jack vines
  15. X-cpe
    X-cpe
    Summit sells a Mr Gasket adapter (MRG8082)to go from the 4GC 4 7/32" opening to the Holley 5 1/8" opening that might be tall enough and give you a wider selection of air filters. If that won't work you could haunt the isles of the Home Depot plumbing department. 4" PVC pipe would work if you Dremel out about a 1/16" from the inside all the way around, then you would have to add a flange to the top. Also look at toilet flanges. Just look at every thing there. A plumbing supply house may even have more. Another thing that may work would be a piece of 4" exhaust pipe if you have a way to expand it to fit over the carb flange.
    409 /340 carb, with 220 horse top ..;-)
  17. 2935ford
    2935ford
    Thanks
    I’ll have a look around.
