Quick question. How can i identyfify if the rear end i have in my 58 chevy truck is a 4:11? I also have a 55 chevy rear end and would like to know what gear ratio it is. Can you guys help me out?
Easiest way: Chalk mark the pinion, chalk mark the axle end. Spin pinion, count number of revolutions to reach one full turn of axle. 4 turns pinion end to one turn of axle equals 4.11.
Non-posi: Jack one wheel off the ground. Turn the wheel 2 complete turns. - Count the turns on the drive shaft. 4.11 turns on the drive shaft equals a rear ratio of 1:4.11 Posi: Jack both wheels off the ground. Turn one wheel 1 complete turn. - Count the turns on the drive shaft.
does tire size come into play here ? like if he has really tall tires, will the tire revolution be different than if he has short tires ? or am i thinking wrong ? you're counting AXLE revolutions correct ? if so, shouldn't the tires be pulled off to do this? as dalesnyder said...mark the axle end.
