Hot Rods Identifying aftermarket axle & wishbone brand?
Discussion in 'The Hokey Ass Message Board' started by wildwest, Jun 25, 2023.
  1. wildwest
    wildwest
    I just bought a 32 5 window coupe out of an estate. I have been looking for a decent coupe in my price range for awhile, and this one was fairly local and is a well built car that should be pretty much what I want once I make some changes. My question is: can any of you guys tell by sight what brand the aftermarket front axle and "split" style wishbones are ?
    The front axle appears to be 46" from the center of the king pin holes (hard to measure with the grille in the way) and has 2-1/4" bosses, and the spring that is on the car (with weight on it) is 29-3/4" from center of eye to center of eye on the spring.
    The wishbone is 40-5/8" from the threaded bung end to the center of the spring perch hole.
    I want to order a chrome non-drilled axle and chrome non-drilled wishbones if possible and be able to use the existing wishbone frame mounts, spring, and other components and ideally have a pretty easy bolt-on change over?
    20230623_190451.jpg 20230625_202123.jpg 20230625_202152.jpg 20230625_202225.jpg
    34 GAZ, dwollam and NoRust like this.
  2. rusty valley
    rusty valley
    The bones look like real ford, 37ish, the axle may be a ford dropped axle too.
    NoRust likes this.
  3. dwollam
    dwollam
    Nice looking car Austin!
    Dave
  4. alchemy
    alchemy
    Axle is a cast repro, looks like a Superbell. I think the wishbones look like the repro ‘40 style that Speedway sells.
    teach'm likes this.
  5. wildwest
    wildwest
    I just looked at the speedway ones, same number of holes, looks like that might be the one.
    If a guy wanted to get an aftermarket Chrome non-drilled axle, but wanted it forged not cast, with 2 1/4" axle bosses, and to go in as easy as possible in place of this one, what would you guys recommend?
    oh, and thanks Dave !
  6. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I think Jason at P&J's told me they are now making a forged 4 inch dropped axle with 2.25 perch width and it's 46 inches center to center. I agree the bones are probably Speedway.
  7. goldmountain
    goldmountain
    I think that if the bones have the weld seam on top, they would be genuine Ford and aftermarket on the bottom.
  8. Superbell would have the remnants of the logo on one side in the centre. Maybe Magnum if not. It's a cast aftermarket axle in any case.
  9. krylon32
    krylon32
    from Nebraska
    When I was using a large number of Super Bell axles in my chassis business when I ordered drilled axles I had them remove the logo from the center and drill all the way across.
  10. dwollam
    dwollam
    I was very happy with the forged axle I bought from Roadster Supply.
    Dave
