Technical idetify ford flathead from image
Discussion in 'The Hokey Ass Message Board' started by Fjant, Oct 18, 2018.
  1. Fjant
    Fjant
    from Sweden
    Hi.
    I might by an old firetruck at an auction just to pull the engine. I did not see the truck in real life, so wander if it will be worth it. Can you se aproximatly what engine it is? the truck is from -52.
    302GMC likes this.
  2. Fjant
    Fjant
    from Sweden
    I wont give more than equivalent to 500 dollars for the truck.
  3. Petejoe
    Petejoe
    from Zoar, Ohio
    Worth that in s****.
    Exposed engine to the elements? It looks like a 59A.
    Your odds of having a rebuildable block or good running engine are probably 25%.
  4. Fjant
    Fjant
    from Sweden
    okey. thank you for the input. the body looks in good shape so, I think it's been sitting inside. but not moved since 1974. But just howling it seems like it's to much work.
  5. oldolds
    oldolds
    Show a picture of the complete truck, please. That looks like it might be a cab over truck. There is value in the body parts. No matter the condition. I see it is England's version of a big truck. It might be interesting
  6. Slopok
    Slopok
    I don't think a '52 would have a crab distributor!
  7. Fjant
    Fjant
    from Sweden
  8. sliceddeuce
    sliceddeuce
    That has Bonneville support vehicle written all over it...…..
  9. 1940Coupe
    1940Coupe
    50’s Ford Thames Firefly
  10. goldmountain
    goldmountain
  11. rustydusty
    rustydusty
    Awesome truck! Looks pretty solid.
  12. alchemy
    alchemy
    I see the bottom row center stud inline with the others above it, so that means it's a 21 stud. It's probably a 1938 engine. Not really popular, but there are some fanatical supporters. Not a 59A engine.
    Bandit Billy and Petejoe like this.
  13. Bandit Billy
    Bandit Billy
    That is one cool truck but damn, that thing has to be one slow fire truck.
  14. flatheadpete
    flatheadpete
    from Burton, MI
    That truck is pretty rad...but yeah, slower than frozen mol***es.
  15. tubman
    tubman
    Seeing you're in Sweden, that might be a good deal. I would be worried about the obvious mismatch in the year of the engine and the year of the truck.
  16. typo41
    typo41
    Ship me the truck, as mentioned a great support vehicle for Bonneville!
  17. redoxide
    redoxide
    Being an english Ford it will most likely be 21 stud motor the same as that used in the Ford pilot well into the 50s so I wouldn't be worried re the relative age of the motor. Its likely to be the one that came with the truck.., They used that 21 stud in the UK all the way through the 2nd WW and beyond. It was also used in pretty much all Ford UK heavy military and Bren Gun Carriers..
  18. Chris
    Chris
    The heads are 37 heads. Looks like it may have a Lucas distributor?
  19. lilmann
    lilmann
    Fjant, do you access to E83W parts..??..I’m trying to track down a grille used around 1950-1957 on the smaller Ford trucks
  20. That is the original motor note the firing order picture on the head that was standard on English flatheads.
  21. Definitely not a 59 or 59A engine. The engine is 1937 or 1938 (note some 38 engines were 24 studs). The head bolts are located directly below the cylinder (lines up with spark plug) which means it is a 21 stud. The water outlet is in the center of the head which places it 1937-38 (the 1936 and earlier heads had the water pumps mounted on the heads and not the front of the engine). These engines are popular with the guys that own 1932-36 vehicles since all of their 21 stud bolt ons will fit on this engine and the engine bay will look almost original (use a plate where the water pump mounts on the front of the engine, Ford actually made a plate for that purpose). These engines have insert main bearings while all of the earlier 21 studs had babbitt bearings. Speed equipment is scarce and expensive for the 21 stud engines. I like it, fix it up and it will be unique.
    Charlie Stephens
    bct, Petejoe and 302GMC like this.
  22. Squablow
    Squablow
    I think the truck is cooler than the engine. As others have said, 21 stud British style flathead. Some aftermarket support but parts are pricey and they don't make as much power as the bigger engines.
  23. khead47
    khead47
    I see a caravan ! ( Camper to us ).
  24. goldmountain
    goldmountain
    I meant hot rod rv; darn spell check.
  25. nochop
    nochop
    from norcal
    I see sumthin cool
  26. deucemac
    deucemac
    Just remember whatever flathead it is, it's in a fire truck and most likely worn out. A friend bought a 1940 cab over fire truck with only 9,000 miles on it but the engine was shot. Fire trucks never go far but will sit and pump or use the pto for hours at a fire thus low miles and incredible hours on the engine.
  27. Fjant
    Fjant
    from Sweden
    thank you for all your anwsers. There was a big sale with about ten different firetrucks (and som other trucks) mostly ford. the other fords were amarican bodystyles i think. all were in the same quite good shape.
    this one was sold for about 1500 dollar (I did p***). The most expensive for about doubble that I think.
