Technical Idle issue
Discussion in 'Traditional Hot Rods' started by mumbles89, Jan 18, 2021.
  1. mumbles89
    mumbles89
    I have a 35 ford that I have been rebuilding and the fateful day came for her to start and she did. The problem is thaf it won't idle on its own. The car will only stay running unless i have the choke flap almost closed and the throttle reveved to 1500 to 2000 rpms tried 1" spacer plate and new seals but still having the same issue. I have a sbc 350 in it with a holley 650 spread bore the carb was also just fully rebuilt by a carb shop. If anyone has any insight or experience with this kind of issue it would be a huge help.
  2. squirrel
    Tell us about the ignition timing
  3. mumbles89
    mumbles89
    With the timing we have it set top dead center but we did also try setting the timing back to 10 before. Because we read a few break in guides and attacked to a couple shops and they recommended it. But that was for having the enginactually at an idle so we went back to top dead center and kept the distributor loose to adjust while it was running which it sounded like it's where it needs to be but idling is 1500 to 2000 rpms. The big thing is when we aren't controlling the carb the engine dies out
    Sent from my SM-G986U using The H.A.M.B. mobile app
  4. 47streetrodder
    47streetrodder
    Vacuum leaks??
    Jibs and Deuces like this.
  5. jaracer
    jaracer
    Sounds like you might not have an idle circuit in the carb, or you have a large vacuum leak. You might want to talk to the carb guy that rebuilt it.
    Deuces and squirrel like this.
  6. swade41
    swade41
    from Buffalo,NY
    Is it a complete fresh engine, used engine with an intake/carb swap, was it running good then you changed something and now it won't idle, if so what did you change ?
    Need a little more info but sounds like a vacuum leak, is it the right carb for that intake, spreadbore on spreadbore ?
    Deuces likes this.
  7. It sounds like a vacuum leak to me. You don't have a large open vacuum port on the back of the carb that needs to be plugged do you?
    Deuces likes this.
  8. squirrel
    How old is the carb? I never had much luck with the 6210, 20 some years ago...at the time, the carbs I was playing with were over 20 years old, and they just didn't age well.
    I'd see about finding a good used Quadrajet to put on it, if you have a spread bore intake manifold If it's a square bore, and you have an adapter to mate the spread bore carb to it, then try an AFB or a square bore holley.
    Deuces likes this.
  9. mumbles89
    mumbles89
    It is a fresh motor that hasn't been run before this was our first time starting it. the intake thats on it is the one that came with the motor or the one that's been on the engine since the late 70s.. It's the intake off of a 71 vette I checked and all the vacuum ports that aren't being used have plugs on them.
  10. mumbles89
    mumbles89
    swade41 likes this.
  11. Do you have anything plugged into that large vacuum port on the back of the intake manifold?
  12. larry k
    larry k
    Put your hands over the carb opening , slowly close off the opening , if the engine speeds up ??? Yep ! you got a vacuum leak somewhere ,!!
    Deuces likes this.
  13. 41woodie
    41woodie
    Do you have a vacuum brake booster? Did you run a hose to it? If you did you might remove the hose from the fitting on the booster and plug it to see if that is the source of the vacuum leak
    Deuces likes this.
  14. Ebbsspeed
    Ebbsspeed
    It does sound like a vacuum leak. Make sure you have the correct gasket between the carb and intake, and also that the secondary ****erflies are sealing their bores tightly.
    Power brakes? Check the hose to the booster.
    Deuces likes this.
  15. jimvette59
    jimvette59
    Get a new Carburetor. JMHO
    Deuces likes this.
  16. gary macdonald
    gary macdonald
    They had a couple of difbase gaskets for the q jet and replacement holley . If you dont have the correct one itll give a small vacuum leak . It can only be identified by removing your carb and checking the seal on both the manifold and carb . Or the riser and the carb AND the manifold
  17. Bandit Billy
    Bandit Billy
    This upload_2021-1-22_12-57-10.png plus this upload_2021-1-22_12-58-17.png equals this upload_2021-1-22_12-59-40.png
    gary macdonald likes this.
  18. Deuces
    Deuces
    Not if you know how to apply the Teflon tape... :rolleyes:
    Norris McCarty likes this.
