1952-59 Ford idler arm install
Discussion in 'Off Topic Hot Rods & Customs' started by BeerMoney, Mar 15, 2020.
  1. BeerMoney
    BeerMoney
    im installing the idler arm on my 55 customline
    how tight should the arm be in the center link and bracket
    if I snug it up I have a little play in it at the drag link
  2. 56longroof
    56longroof
    There is a certain procedure to it. I still have a copy of the article on rebuilding the front suspension on these cars. I can get it for you later today.
  3. evintho
    evintho
    Now, this is for a '54 but my FSM says to tighten the idler arm to mount bracket 85-100 ft. lbs.
    Idler arm to steering arm (center link) tighten to 85-100 ft. lbs. also. Remember, they're reverse threads!
