If I run a mag can't I spin the alternator off the driveshaft
Discussion in 'The Hokey Ass Message Board' started by willbierfarms, Nov 9, 2013.
  1. willbierfarms
    willbierfarms
    from palmyra mo
    Years ago in hot rod and I mean years ago they had a offy powered roadster pickup that was running the alt off of the drive shaft. On this banger I'm putting together what's stopping me from doing the same thing? I'm gonna run a magneto so that eases up the charging system no radio to fool with so your down to the ights and starter. Just run a deep cycle large cca battery right
  2. Yes you can. the driveshaft should spin the alternator at a faster rate than the shaft turns...just like it does at the front of the engine (if you want the same charging ability).
    If you can tolerate reduced output, you can spin it slower. The radio takes so little electricity, that its use will not have a big effect. If you can put it on a charger every day and not use the lights, you might even be able to get by with no alternator if you are using a magneto.
    (I assume you will not have other things like a heater or electric radiator fan. )
  3. willbierfarms
    willbierfarms
    from palmyra mo
    I plan on running a electric fan so I will need an alt. That's about it other than lights and the starting circuit.
  4. willbierfarms
    willbierfarms
    from palmyra mo
    I found a mount kit for the winters q/c on eBay I just need to figure out how fast to spin it. And do I run a big high amp alt or just a normal one
  5. ROADSTER1927
    ROADSTER1927
    Your electric fan will draw quite a lot of power so a larger alt would be my choice. Gary
  6. And the alternator or course will not be turning while the car is sitting still.
  7. blowby
    blowby
    from Nicasio Ca
    And the times when the fan is really needed the alternator won't be spinning...
  8. JohnEvans
    JohnEvans
    from Phoenix AZ
    AND !! what is going to drive the water pump ???
  9. rottenleonard
    rottenleonard
    It's common to get just the right size of belt to drive the w/p without a tensioner like an alternator.
  10. rfraze
    rfraze
    Look for one that puts out high amps at idle, since it will always be run at a comparatively low rpm.
  11. Rickybop
    Rickybop
    Or you could get one of these. Racemate combo water-pump/alternator.
  12. Jethro
    Jethro
    Wow!, Except for the serpentine belt what a cool way to solve a common problem....never seen one of those!
  13. Crusty Nut
    Crusty Nut
    I ran one off the driveshaft for years. Dont use a 1 wire since they have a higher excite rpm. Mine would start charging nearly right away, like 7 mph. My set up ran an electric fan, lights, dizzy, and never gave me a problem.
  14. Rickybop
    Rickybop
    They have V-belt pulleys, doubles, even Gilmer-type. I don't know about serpentine aplications, but I bet that could be worked out too.
  15. blowby
    blowby
    from Nicasio Ca
    When you do run one off the drive shaft, where do you mount it? Everything's moving in and out and up and down back there.
  16. henryj1951
    henryj1951
    from USA
  17. austinhunt
    austinhunt
    They mount directly to the rear end.
  18. I have a Joe Hunt, electric fan, electric water pump, and ran the alternator off the driveshaft.
    Did it for about 5 years and always carried a jump box in the trunk.
    I had to jump it numerous times.
    Night time driving and long lines of heavy traffic were a killer for me.
    I finally put a mini alternator on the engine and never needed a jump again.
    Yes it looked trick, always drew comments, but it was stupid.
