If not Stockton, who mods steel wheels to order?
Discussion in 'The Hokey Ass Message Board' started by DocsMachine, Nov 29, 2005.
  1. DocsMachine
    DocsMachine
    from Alaska
    I keep running across a few "Stockton Wheel ****s!" type threads, which has made me kind of leery. I was going to have them mod some wheels for me, but I don't want to wait six months...
    So here's the deal: I have a '66 Olds Toronado, which is FWD of course, and uses wheels with a lot of offset. I've looked, and there's no aftermarket wheel that will fit, without some radical surgery. The plan then, was to have a shop like Stockton press the centers out of some stockers (I have a pile of 'em) and press them into new outers.
    The stock rims are 15"x7" wide, and I was hoping to bump that up to at least 17"x9", or even 18"x9".
    It's also a very heavy car (pushing 5K lb) and any modded wheel needs to be able to withstand both the weight and the torque (over 500 ft/lb.) I was also looking for either chrome or powedercoat.
    So is there a shop out there that can do something like this, as well as Stockton, but perhaps more reliably, or better quality, or just faster? And about what is something like this going to cost per wheel, if you know?
    Thanks.
    Doc.
  2. ponchoman
    ponchoman
    Pete Paulsen. I wouldn't use anyone else.
  3. mojo66
    mojo66
    Wheelsmith in Cali.
  4. TV
    TV
    Wheelsmith has done several sets for me and always been fair and done good work.--TV PS he is in so. Cal.
  5. 5window
    5window
    Pete built my wheels. They look nice and 3/4 are fine one is slightly out of round but usable/cruisable. It balanced but I wouldn't race w/ it. However,check recent posts-Pete's not done so well with other folks. Saw this ad in the recent Street Rodder-you might check them out:
    www.team3wheels.com
    Says they make them all to order.
  6. D.W.
    D.W.
    from Austin Tx.
    Do a search fof Pete Paulson. Read, learn, run the other way. I used Wheel Vintique. I was happy.:)
  7. Paul2748
    Paul2748
    If your near NJ, Wheel Works 609-499-2233. Hear a lot of good things about them, never used them myself.
  8. stan292
    stan292
    Doc-
    Sorry, no help with wheel modification sources, but I need a question answered - if you would be so kind.
    I'm using a rear end out of a '65 (full-size) Pontiac for my hot rod and (since the rear end is sooo wide) had thought about the possibility of using Toronado wheels - because of there extreme inward offset - to effectively narrow my overall rear-end tread width (without spending the big $$ to have the axles and housing cut down).
    I've prowled the local swap meets for years and have never run across any to find out for myself. So, my question is: Do those early Toronado wheels use the '"standard" 5-lug Buick/Olds/Pontiac bolt pattern (i. e., will they fit on my "big Pontiac" axles)?
    If so, you mention having a "pile" of them. I didn't see anything regarding where you live, but if it's within reasonable driving distance of me (SE Nebraska), I'd be interested in buying a pair.
    Thanks -
  9. scottrod
    scottrod
    I've used Wheelsmith twice and I can say they are definitely fast!
  10. Von Franco
    Von Franco
    Wheelsmith rocks the fastest and no ********..............
    Endsville ........................
  11. muffman58
    muffman58
