If you smell something, it's just the paint I'm about to lay down!
Discussion in 'The Hokey Ass Message Board' started by OfficerBimbo, Mar 2, 2013.
  1. OfficerBimbo
    OfficerBimbo
    A question for all you paint gods and goddesses out there in hot rod land:
    I will be painting some graphics down over black epoxy primer in a few days. The paint is a ppg Shopline acrylic urethane (jau code). How long do I wait, after applying the paint to remove the masking tape? I have been told one to two hours- is that right?
    Thanks for your help!
    Earl Sheib **XIV
  2. Gman0046
    Gman0046
    Graphics, Graphics, no one has put down Graphics since the early nineties.
  3. Abomb
    Abomb
    Wait for it to flash, which ought to be less than 30 minutes if you are using to proper reducer / activator. Then be very careful, pulling the tape back against itself. If you let it dry too long, you run the risk of pulling your graphics up with the tape.
  4. Bugguts
    Bugguts
    Yes, 1 to 2 hours sounds right. Don't leave the tape on overnight, I like to remove tape before the paint has totally set up for sure.
  5. clean cut creations
    clean cut creations
    What does the tds for your product say?
  6. Butcher's Shop Customs
    from Paducah KY
    I pull my tape when the paint flashes. Every time I've waited any longer, it's bit me in the ****.
  7. ronk16
    ronk16
    depends on the conditions you are painting under, in my booth solvent based paints flash off about 10 to 20 minutes . Temp, reducers and who is spraying make a big difference.
  8. Xdrag48
    Xdrag48
    I wait about 15-20 mins.Then I start touching the painted tape with my finger If it is tacky I wait if my finger does not stick anymore I start pulling the tape.Check every 15 mins. or so times vari....
    Steve
  9. TR Waters
    TR Waters
    from Vermont
    Use good tape.
  10. OfficerBimbo
    OfficerBimbo
    Thanks for the help guys!
    Sorry Gman- I was just trying to speak in terms you would understand. Didn't mean to get your mullet in a ruffle...
  11. loveoftiki
    loveoftiki
    from Livonia,Mi
    Amen to that! Nothing better than slivering during tear off and adhesive transfer. 3M 233+ is the way to go
  12. OfficerBimbo
    OfficerBimbo
    I've got the 3m 233 too. Good stuff!
  13. robertsregal
    robertsregal
    As stated I always pulled off tape after paint flashed and at a sharp angle as to help cut paint and do not go too fast.
  14. OfficerBimbo
    OfficerBimbo
    Thanks guys for all your help. It came out pretty good for my novice level work...
  15. OfficerBimbo
    OfficerBimbo
    Here is another pic. I had some better ones but they are not uploading for some reason...
