If your having trouble posting photos check here
Discussion in 'Questions & Suggestions' started by hotrodladycrusr, Feb 7, 2005.
  1. hotrodladycrusr
    hotrodladycrusr
    Last nite I was trying to help out three different HAMB guys that were having trouble posting photos using a photo hosting site. I've been sitting here at work thinking that if there were three that came forward and asked for help there are probley quite a few more sratching their heads wondering what they are doing wrong.
    For the 3 guys last nite there was not the two rows of icons for them to choose from. All the fancy posting stuff never showed up for them. If you do not see the two rows of icons like in the example below, then follow these steps to change one of your settings. It's very easy, don't be scared. :D
    If you need further ***istance, check out this post from last nite and see if it helps at all.
    http://www.jalopyjournal.com/forum/showthread.php?t=43834
    If you do not see the "insert image" icon it's because one of your settings in your user control panel is not set right.
    Go to "user cp" located at the top of the page
    go to "edit options"
    scroll down to the bottom, under "misc. options", see the little box on the bottom right with the little tringle. Click on that tringle and some choices will drop down. Choose "Enhanced Interface- Full wysiwyg Editing".
    Click "save options"
    Now you will see the two rows of icons that the rest of us see.
    Thanks to Blacksix for supplying the following image.
    __________________
  2. 296 V8
    296 V8
    from Nor~Cal
    Thank you
    Finally someone has pinpointed the problem.
    I was trying to use the “manage attachment” ****on and all I was getting was “invalid image”
    I was starting to think my on line album was not going to work with “new hamb”.
  3. hotrodladycrusr
    hotrodladycrusr
    Your welcome. I knew there were more guys out there having trouble.:D
  4. I should say "thank you" too.....!
  5. 29SX276
    29SX276
    HRLC;Thanks for this item;you answered my question.What's the URL thing before inserting pic?Is that the picture file :eg "8BA oil plug.bmp" and shows a pic of an oil plug ***embly?I'm really 'puter challenged!!!!
