Technical Ignition coil
Discussion in 'The Hokey Ass Message Board' started by Harleyv89, Apr 12, 2023.
  1. Harleyv89
    Harleyv89
    Hi,
    is there anything i need to know before changing from a coil with a external resistor to a coil with a built in resistor?
    also is it as simple as just throwing away the secondary wire from the resistor and placing the other wire straight to the positive?
    thank you
  2. Bob Lowry
    Bob Lowry
  3. Harleyv89
    Harleyv89
    Easy done thanks mate, i know its pretty straight forward but always good to make sure haha
    Bob Lowry likes this.
  4. hepme
    hepme
    I've done it both ways, a lot both ways, and IMO the external w/ coil is the most dependable. Have a tractor (?) that I used the internal on, time and again it just flat failed. I think I went through 4 or 5 coils, always under warranty (whew!). Went to the external and its still on and going strong after 3 seasons (Texas tractors work hard, tons of heat, dirt, etc.) Found the same on a car, did not fail as frequently though. Just my opinion.
  5. 302GMC
    302GMC
    from Idaho
    I've used Bosch blue coils on 12v changeovers for decades. I have never seen an OLD Bosch fail.
