Technical Ignition issues
Discussion in 'The Hokey Ass Message Board' started by Dan Yager, Dec 6, 2021.
  1. Dan Yager
    Dan Yager
    Got the 241 back together after stuck exhaust valve. Now she won’t start. Good lord what next. When the valve originally stuck we couldn’t get it to fire again. Any ideas out there? I replaced points in distributor with electronic ignition. Coil has ballast resistor built in. I’m at a loss
  2. Do you have spark at the plug ?
    spark at the coil ?
    good battery ?
    compression ?
    why did you swap ignitions ?
    budweiser or Heineken ?
    tommyd, tom in nh, Blues4U and 3 others like this.
  3. squirrel
  4. connielu
    connielu
    1. A-D Truckers
    Most electronic setups need a full 12v. Has it run with the new setup?
    VANDENPLAS likes this.
  5. Dan Yager
    Dan Yager
    Connie Lu yes it has ran a few times and ran great
  6. Dan Yager
    Dan Yager
    Squirrel. Lots of fuel, good spark and compression
  7. Dan Yager
    Dan Yager
    Van den plays. Good spark. Got fuel and compression. The builder swapped it out to electronic ignition. I’m wondering if it’s getting too much fuel. Fresh rebuilt stromberg and pressure was set to 3.5 lbs
  8. squirrel
    What do the plugs look like? If they've all got wet, might try a fresh set of plugs.
    Dan Yager and VANDENPLAS like this.
  9. Dan Yager
    Dan Yager
    Squirrel yes they are wet that’s kind of why I’m thinking too much fuel
  10. Disconnect the fuel line to the carb.
    dribble some fuel down the carb or give it a snort of quick start just to see if it will fire.
    That will confirm your ignition is good .( or at least close )
    Coild you possibly be 180 out on the distributor ?
    did you do anything to your carbs or fuel pump since the last time the car ran ?
    wet plugs could be over fueling or crappy spark .
    Dan Yager and Johnny Gee like this.
  11. squirrel
    in some cases, once they get wet, they won't fire again....
    Make sure it's getting spark, and at the right time. Make sure that there's fuel in the carb but not flooding over. Put fresh plugs in, see if it fires.
    Dan Yager likes this.
  12. connielu
    connielu
    1. A-D Truckers
    Yep
  13. F-ONE
    F-ONE
    from Alabama
    PCV/vacuum hoses connected?
  14. Dan Yager
    Dan Yager
    Vandenplas. Turned out to be too much fuel. When it was shut off fuel just poured out of base gasket and throttle shaft. Float was way out of whack. Too much fuel brother. Pulled plugs 4 times and cleaned them. Problems solved. Thank you for your thoughts
    VANDENPLAS and squirrel like this.
  15. Dan Yager
    Dan Yager
    F-one. Just too much fuel from rebuilt carb. I think I got screwed out of the $280 rebuild
  16. Dan Yager
    Dan Yager
    Squirrel. Yup. Too much fuel fowling plugs. Adjusted float and boom!!! Yes I discovered the holding gas pedal down! Thank you
  17. F-ONE
    F-ONE
    from Alabama
    Floats stuck?
    Check the carburetor base and gasket. A vacuum leak somewhere can drive you nuts.
    Dan Yager and Elcohaulic like this.
  18. birdman1
    birdman1
    Spike the coil
