Technical Ignition switch question
Discussion in 'The Hokey Ass Message Board' started by Sporty45, Jan 6, 2021.
  1. Sporty45
    Sporty45
    I have a switch I want to use in my 47 Olds project from an OT Chevy. It has all the usual terminals on the back plus a couple I have no idea what they do. The ones in question are marked Key+ and Key-. I've tried hooking up my meter to see what they do, but can't get anything no matter how I hook it up! Don't really think I need those 2 terminals, but would like to know what they are for. Any help appreciated.
  2. 1971BB427
    1971BB427
    from Oregon
    Have you checked with your ohm setting the continuity between Key- and GRD? And between BATT and Key+? In both off and on positions of the key? Also between Key+ and Key- with the ignition on?
    That's a late 60's GM ignition switch, as earlier '65 and older had just 5 terminals. The 7 terminal version was first offered in 1966. Diagrams for that year simply call those terminals "Ignition #! and Ignition #2"
    Sporty45 and Crazy Steve like this.
  3. Sporty45
    Sporty45
    Yes I have, that's what has me baffled. It doesn't seem to matter how I hook up my meter :confused:
  4. Sporty45
    Sporty45
    In that case, shouldn't I be able to determine the path of electricity using my meter? Nothing in the switch seems to connect to those terminals!
  5. jaracer
    jaracer
    Possibly set up for a key with a resistor in it?
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Head light doors?
  7. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I took that reply down. Only GND terminal does what I described. Sorry
    Sporty45 likes this.
  8. Sporty45
    Sporty45
    Too early for a chipped key I would think. It's for a 68 Chevy, don't think they had them then?
  9. Sporty45
    Sporty45
    Maybe, but still can't follow the path of electricity
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
  11. Sporty45
    Sporty45
    Well there ya go! What the hell is a key buzzer though?
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Tells you that you left your keys in the ignition when you open the door.
    302GMC and Sporty45 like this.
  13. mario711
    mario711
    My '57 has the Ignition #1 and Ignition #2 wires having to do w the coil connection/resistor
  14. So what you'll find is continuity between the two 'key' terminals when the key is inserted, they go open when it's out.
    I also suspect that if you check the 'ground' terminal to the switch case, you'll have continuity between them when the switch is off and no continuity when the switch is turned to any other position. That would shut the buzzer off when the key is in use.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The ground terminal only make contact when key is turned fully to start position to illuminate idiot light/lights as a test bulb function only. Especially important for temp purposes.
  16. That's a possibility also, although I suspect it's to check the new-for-67 brake warning light.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The GRD terminal goes several years back earlier than 67.
  18. Sporty45
    Sporty45
    Tried all that and still got nothing. This is a brand new AC Delco switch, not aftermarket. I know that doesn't always guarantee it is good, but was hoping! At least all the other terminals work as they are supposed to. And yes, the ground terminal works when switch is turned all the way to start position. Don't plan on using lights though, just gauges.
