Customs Ignition switch removed
Discussion in 'The Hokey Ass Message Board' started by David O Smith, Oct 16, 2021.
  1. Anyone
    100.0%
  2. Anyone
    0 vote(s)
    0.0%
  3. Anyone
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. David O Smith
    David O Smith
    I have a 1954 Ford Custonline trying to figure out how to get the outer ring off the ignition switch. Any help
  2. pprather
    pprather
    lothiandon1940 likes this.
  3. saltflats
    saltflats
    from Missouri
    Wow, first post and you figured how to start a pole.
    Most just unscrew, but some some you need to take the key tumbler out first.
    Johnny Gee likes this.
  4. goldmountain
    goldmountain
    On some cars, you turn the key to ACC, get a paper clip and push it into a little hole by the key, and then pull out the lock cylinder. Then that is out of the way and you can remove the trim ring holding it in the dash. Some of these unscrew and other ones release with a quarter turn or thereabouts. Or I could be totally wrong.
    alanp561 likes this.
  5. Reach under the dash, grab the switch and gently push forward, Turn the Chrome Bezel counter clockwise till it stops and retract the switch. There are notches on the inside circle where the Key enters you can insert a flat blade into if necessary.
  6. oldsman41
    oldsman41
    Pist n broke won the prize that’s how you do it
  7. David O Smith
    David O Smith
    Thank you Pist n broke
    lothiandon1940 and Pist-n-Broke like this.
  8. David O Smith
    David O Smith
  9. David O Smith
    David O Smith
    Thank you for your help
  10. David O Smith
    David O Smith
  11. David O Smith
    David O Smith
    Didn't know that I started a pole or how I did that.
  12. David O Smith
    David O Smith
  13. David O Smith
    David O Smith
    There's no pin hole on my 54
  14. He missed the part where you said FORD. His routine is for G.M's
    Moriarity, Bob Lowry and Hnstray like this.
  15. Truck64
    Truck64
    from Ioway
    Poles are for strippers
  16. 51504bat
    51504bat
    The Ford shop manual describes the removal procedure. If someone doesn't post the info I'll go down to the shop later this morning and post the info. I'm in the process of rewiring my '54 Ranch Wagon and the ignition switch is currently out. I'll take some photos when I go to the shop.
    David O Smith likes this.
  17. 51504bat
    51504bat
    This is from the Ford shop manual. Also some photos of my bezel ***embly and the tool I made to remove the retaining nut. 20211017_060058.jpg 20211017_060118.jpg 20211017_055720.jpg 20211017_055625.jpg 20211017_055615.jpg
