ignition switch wear??
Discussion in 'The Hokey Ass Message Board' started by The Bomber, Feb 22, 2009.
  1. The Bomber
    The Bomber
    from mass.
    Buddy of mine has a 47 Ford coupe with 350 chevy,350 trans etc. also
    has a GM steering column with an ignition switch.Car also has a Ron
    Francis wiring kit. car was fine when he first owned it. Recently, when
    you shut it off the gauge lights stay on thus draining the battery,battery
    is new. Seems like the "run" circuit is getting power from the ""bat" or
    "hot" circuit when key is off. He called Ron Francis,they walked him through it and every wire is where it supposed to be. A few people men-tioned the possibility of the ignition switch being worn out therefore it
    can't cut off the power. But, I hardly ever hear of them wearing out,
    possible though? Would I be able to tell quickly by putting a test light
    on each terminal where it comes out halfway down the column onto
    the harness? Thanks for any help.
  2. Gerg
    Gerg
    It's very possible for them to wear out especially with a heavy keychain hanging on them all the time. like anything else it can wear out
  3. propwash
    propwash
    from Las Vegas
    the part that the rod moves is pretty hard to wear out, but I don't think it's really all that expensive. Swap it out and see what happens. Only other thing I can think of is that sometimes the alternator will feed back into the electrical system if you don't have a way to keep the current flowing in one direction only (diode?). Problem is that if it wasn't doing it originally and it is now, there could be other problems (generally referred to as "feedback").
    dj
  4. Cruiser
    Cruiser
    Since your friend has a Ron Francis wiring, isolated the stater wiring and hook it up to a universal starter switch and see what happens. If it works fine then your column switch is bad. Might be a bare wire shorting out on another wire.
    CRUISER :cool:
  5. Von Rigg Fink
    Von Rigg Fink
    from Garage
    I had a 66 el-cameno that you could start the car with the key and than take the key out..it would remain running...to shut it off you put the key back in and turned it off
  6. Jalopy Joker
    Jalopy Joker
    Yep, your idea of checking things with a test light is good. Yep, ignition switches wear out.
  7. Switch is on the lower column. They have a slight ajustment. Maybe loosen the two screws and move it up and down to see if the light goes out.
  8. badlefihand
    badlefihand
    Had a similer problem,after checking and rechecking again and again I had new keys made,wore so much that the key did not turn tumblers enough.
  9. Tazzio
    Tazzio
    from colo.
    There is a rod connected to the switch that is hooked to a rack and pinion type gear setup were the the lock cyl. engages, on the early columns those gears were made of a plastic or nylon type material. You might want to pull the ign. cyl. out and check to make sure that those gears are ok. Sometimes a tooth will break off of one of the gears and the rod cannot make it's full travel.
  10. When I was in high school, the ignition switch on my '55 Ford was so worn that I've had the key fall out of the switch when I hit a bump in the road.
  11. stuart in mn
    stuart in mn
    As mentioned, it's possible for one of the diodes in the alternator to go bad, and it will allow the power to backfeed through the idiot lights when the key is off.
  12. the power for gauge lights should come off the headlight switch terminal marked "dash lights" or something like that . the ignition switch should have nothing to do with it.. as it is battery power and not switched through the ignition switch . some wires must be wrong .
    do you mean the gauges them self, or the lights in the gauges?
  13. The Bomber
    The Bomber
    from mass.
    It's the gauges themselves, not the lights on the gauges.
  14. i've had a switch go bad , so yes it is posssible
    the switch may also be slightly out of adjustment...the two mounting screws on the switch are slotted , maybe they are loose and it moved. in switch itself , if you look inside with a magnifying glass you will see terminals marked: B for battery , I-1 for the ignition circuit , I-3 for things that need power when the ignition is on , A for accessories , S for start
    with the key in the off position , check to see if there is any power with a test light at I-1 or !-3.
    maybe an adjustment will fix it, as 325w suggested
  15. Johnny1290
    Johnny1290
    Sure they wear out. Unless the switch was new when the harness was installed, well, who the heck knows how old it is? When I put in a new harness, I want the whole thing new, including switches and plugs, so I know what I have and everything is up to snuff.
    I just looked on the 'bay, a new switch is around $20, I'd do it if for no other reason just to eliminate it as a possibility. If R. Francis thinks it may be at fault,then I'd listen.
    JM2C
