ignition switch wiring QUESTIONS help S.O.S !!!!
Discussion in 'The Hokey Ass Message Board' started by lgh1157, Oct 28, 2006.
  1. lgh1157
    lgh1157
    So i wired the galaxie over the last few weekends with a EZ wiring kit, i checked everything today and most of its working, however i am having trouble with wiring the ignition switch - the kit is all GM color coded, but it looks easy enough, but no matter which way i wire it, it aint working right.
    This is what i have :
    6 wires
    IGN Sw power
    IGN Sw start
    IGN SW ACC
    IGN SW coil
    IGN SW IGN
    the 6th wire comes off the RED IGN Sw start wire, i guess its a ground because its black
    The diagram says the IGN SW coil and IGN SW IGN go to the same post
    The problem i am having is i dont know which posts these wires are supposed to go on, i thought it looked pretty obvious, when i had everything wired as the diagram shows, the starter solenoid was trying to crank in the "on" position
    Which one is the battery post ? - the top one ?
    Does the purple wire "IGN Sw start" go to the center post like in the EZ diagram ? if so, something is ****ed up somewhere else
    Pics :
  2. squirrel
    the problem is you have a Ford switch, and the diagram is for a universal switch....they ain't the same!
  3. lgh1157
    lgh1157
    Meaning i cant use it ?
    Or can i make it work ?
    ****, i dont wanna buy a universal one
    L
  4. squirrel
    You can make it work, but you have to figure out which terminals do what. I don't see any markings on it like S A I B so you need to either use an ohm meter or test light, or find a wiring diagram, or maybe find the old harness and see what colors the wires were that were connected to it, and maybe we could figure out which was which.
    maybe I do have a diagram, I'll go look
  5. squirrel
    maybe this will help?
    I think C is coil, B is batt, A is accessories, and S is starer solenoid
  6. plan9
    plan9
    i cant see any markings on the terminals... you could try different combinations to get the ignition to work, hook one thing up at a time or you will get confused.
    call EZ wire if all else fails. i had the same problem with my ign switch, didnt know what was what.
    also, make sure your ground is good. you will go ape **** over phantom problems if you have a faulty ground.
  7. i would find a wiring diagram for what ever the switch is from. if it's for that car use the old wires in conjunction with the schematic to make it work.
  8. plan9
    plan9
    dont think this will work..
    he didnt know it was a ford switch, (im guessing the give away is the centraly located battery terminal).
    it is possible to trace wires to their sources ***uming the wires havent all been pulled out already. simple things to overlook when dis***embling a wiring system.
  9. lgh1157
    lgh1157
    what the **** you talkin bout nikka !
    I wired this mother every ****in way possible, and the grounds on the car are fine.
    I'll **** with it tomorrow,
    Mike the club "meeting" was fun, when you coming back to the land of drugs, gangs, pimps and hoes ?
    L
  10. squirrel
    nice schematic, no different than what I posted....although it's a bit cyptic.
    Here, I turned the picture of your switch over to make it match the old wiring diagrams, and labeled the terminals on it....should be all you need to get it going, hopefully
  11. plan9
    plan9
    as soon as you wire that muther****er up and pick me up haha...
    nah, kiddin... my parole officer said i have to stay put
    wish i could have been there, but i gots to make that paper....pour some maple syrup for the homies that couldnt be there.
    try squirrels wiring set up... perhaps you should take the engine out and remove the rear end? that might help you figure out the wiring. :D
  12. lgh1157
    lgh1157
    Squirrel - soon i will be rewiring another car
    Just wanted to say thank you !!!!! . . . . . 8 years later :D
    L
