Technical Ignition wiring woes
Discussion in 'The Hokey Ass Message Board' started by G ., Nov 30, 2017.
  1. G .
    G .
    from Austin
    I've used the search feature!!!
    I can't seem to find a wiring diagram I'm happy with that covers what I've got going on.
    12v system
    Pertronix Ignitor II
    Accel 1.4 ohm coil
    GM Alternator
    Two post keyed switch*
    Push ****on starter*
    I wired it up using the diagram in the shop manual, but apparently my eyes are getting bad because those lines are super hard to read... especially covered in grime and age. I've got power to coil, but no spark. Before I double check all my wires I wanted to see what y'all had to say.
    I should also point out that I did this lastnight in the dark, with a dumb spelunker headband flashlight on- it's entirely possible I missed something and was just tired and pissed off when I gave up.
  2. Poh
    Poh
    from Quincy,Ca.
    Black wire from distributor to - coil, orange wire to +coil ? Mine is a flamethrower small base hei, though the wiring should be the same.
  3. squirrel
    Once you figure out how you wired it, let us know, and we'll see if we can help you figure out what's wrong.
    Right now, there is nothing to go on. At all.
  4. Poh
    Poh
    from Quincy,Ca.
    Donuts & Peelouts likes this.
  5. You said it. Start fresh in the morning. In the daylight. After coffee.
    G . likes this.
  6. Sheep Dip
    Sheep Dip
    from Central Ca
    G . likes this.
  7. Truck64
    Truck64
    from Ioway
    Headlights are the best thing since sliced bread.. better than a flashlight anyway
  8. G .
    G .
    from Austin
    Yeah I noticed that... seemed to be some confusion in some of the posts I read online about the ignitor I/II and 6v-12v systems. Just ordered the correct part and will be here in about an hour.
  9. G .
    G .
    from Austin
    Off the top of my head, this is what I've got.
  10. squirrel
    If it's wired like that, it should work, I think.
    I guess you need to double check.
    The coil resistance...kind of relates to whether or not you use a ballast resistor. If it's a coil that has a higher resistance and is not designed to use an external ballast resistor, then it should be fine.
    Poh likes this.
  11. check the installation instructions for the Ignitor II.....i believe they want .6 ohms coil
  12. G .
    G .
    from Austin
    Had to print them out from their website- my box came with the wrong tech sheet for my model.
    rfraze likes this.
  13. Poh
    Poh
    from Quincy,Ca.
    ? Get spark?
  14. G .
    G .
    from Austin
    I gotta wait until tomorrow morning to work on it- it's killing me.
    Poh likes this.
  15. rfraze
    rfraze
    Try it with the start ****on connected to the battery positive, instead of to ignition hot, and check that coil + (and pertronix module) stays hot while cranking.
    G . likes this.
  16. G .
    G .
    from Austin
    Tried it with a modern ignition key switch and went through each wire again... still no spark. Ruled out wiring, coils, switches... pertronix unit is now suspect. I've never had so much trouble with ignition wiring before.
  17. G .
    G .
    from Austin
    I'll go ahead and try this too.
  18. G .
    G .
    from Austin
    Does anyone know how to test a pertronix? This is an 1168LS.
  19. rfraze
    rfraze
    Does module have power w/ign on and while cranking?
    You can insert a straight pin into the wire insulation or connector to provide a place to connect test light or meter.
    If module does have power even during cranking (starting), but no spark, module may be bad. It should ground coil negative each time reluctor p***es window. Make sure distributor is grounding to block and to Bat -.
    I have chased points ignition problems and found points that were not grounding thru distributor. Ground for module has to come thru dist. body. Hope this helps. Good luck.
    G . likes this.
  20. G .
    G .
    from Austin
    This is exactly the issue. Pin through + insulation, connected to test light- lights up with key on and pulsed slightly while cranking... no spark.
  21. pprather
    pprather
    What is voltage while cranking? The Pertronix wants a full 12 volts while cranking to fire the engine.
    Phil
    rfraze likes this.
  22. G .
    G .
    from Austin
    As it turns over, the multi is between 9 and 11v- staying around 11v mainly.
  23. Like pprather said, 12v min.
    Ben
    rfraze likes this.
  24. pprather
    pprather
    I think Pertronix may say that is marginal.
    I had Ptrix and would start when I let off the key, but not while cranking. Not enough voltage.
    Put in a GM hei, which is more forgiving, fired immediately.
    A couple years go by and started having the same problem with hei.
    Decided to start with a new battery. Found a splice in positive cable, made by a previous owner had deteriorated over the years. Strange things can cause a low voltage while cranking problem.
    I would start by looking at the ground circuit, from battery to engine to starter.
    Hope this helps.
    Phil
    rfraze likes this.
  25. Truck64
    Truck64
    from Ioway
    You wanna feed it full battery voltage because it's always going to sag some when the starter soaks up all that juice, even with a good battery. Make sure cables are good and ground connections are clean and tight. Spec is when a battery drops to 9.6 volts during cranking it's time for a new battery.
  26. G .
    G .
    from Austin
    Battery grounded to block/block to frame in two separate places. Distributor case is also grounded to block. I've cleaned every piece of metal and every contact point for grounds and for batt +.
  27. wbrw32
    wbrw32
    Your Petronix is mounted incorrectly..It should be mounted in the trash can
    Truck64, King ford and rfraze like this.
  28. G .
    G .
    from Austin
    Apparently. Should have just went hei distributor like I do with everything else but nooooo.
  29. G .
    G .
    from Austin
    Just tried it with an even newer battery out of my 69 Impala... 11.5v cranking... nada.
  30. rfraze
    rfraze
    Remove the + wire from coil to Pertronix module and connect a jumper from Battery to that wire, then check for spark with key on and coil hot.
