ignition wiring
Discussion in 'The Hokey Ass Message Board' started by north side, Feb 12, 2013.
  1. north side
    north side
    from texas
    hey guys, Im trying to put a 1978 302 in my 51 F2, im looking for a wiring diagram for the electronics of the 302,ie.. the coil, ignition coil and distributor. the previous owner stripped all the wiring off and the pigtails and connections are gone. Can anyone point me in the right direction to get a wiring diagram? thanks...The cab is off the truck and I would like to start the motor, so Im sure its just gonna be a few of the wires that need connected,I just dont know where to connect them...
  2. willymakeit
    willymakeit
    Do you have a Chiltons or sim. manual for the year of motor?
    Need the diagram for your truck also.
  3. north side
    north side
    from texas
    the distributor has 3 wires coming out of the bottom, the ignition coil has 2 sets of wires from it? i ***ume this is electronic ignition because i dont see point in the distributor
  4. north side
    north side
    from texas
    all the wiring for the truck is toast, and the previous owner swapped the motor and ****** , i was able ,by the block numbers to find out the block is a 1978 302
  5. vtwhead
    vtwhead
  6. north side
    north side
    from texas
    yes it does thanks. im looking for info on what to connect to get it started, the cab isnt on the truck and there isnt a ignition switch
  7. It's probably a Duraspark. This one is from a 79...
  8. BTW, it won't work without the "box".
