Projects I'm all in...My '38 Chevy PU Build Thread
Discussion in 'The Hokey Ass Message Board' started by pila38, Aug 2, 2013.
  1. nunattax
    nunattax
    good on ya
    pila38 likes this.
  2. pila38
    pila38
    Here’s what I’ve been up too the last few months to get to this point:
    Got the clutch setup, which turned out to be the toughest of the pedals to setup. I bought a z-bar package for a ‘56 Chevy because it seemed to have the closest dimensions to what I needed and included all the necessary pushrods, balls, clips, seals, etc….
    Ended up using almost none of what was included. Had to cut the z bar in the middle to narrow it to fit my frame and reposition the tabs correctly for my application. The upper pushrod from pedal to z bar was too long, so I cut it down and welded back together, only to later find out it was now too short, by about an inch. So I made a whole new one with some 3/8” steel rod and yokes I had around. (One of my twin daughters came out to help me thread the rod). Once that was accomplished, the head of the pin holding the lower yoke to the z bar, hit the frame. So….out came the die grinder and a notch was made.
    The lower pushrod for the clutch was the style that goes through the fork and is pinned in. That is not the style clutch fork I have. So…I cut the pin tab off and rounded the end to fit in the pocket on the fork.
    Finally, got it pretty close on the adjustment and will finalize it when the brake pedal is done so I can put them at even heights.
    Sorry I don’t have many pics of this process, I did this not long after my dad p***ed and lost my zeal for wanting to post.
    LAROKE, tb33anda3rd and swade41 like this.
  3. pila38
    pila38
    Once the clutch was sorted out for the most part, I moved on to the throttle. Mostly because the brake set up I’m using requires a lot of thought, and that scares me, haha.
    Throttle was pretty simple. Used some 5/16” rod ends and tube and a simple Mr. Gasket bell crank. The fabrication itself was pretty straight forward, but it did take some time to figure out the physics so that it would not bind or catch on anything in its arc of travel.
    Now I need to find some type of grommet that will fit the huge hole I needed. I’m think I may cut some normal grommets and use some of the foam that comes with new toolboxes to accomplish that. However, that is a future me problem to be solved after paint.
    LAROKE, Stogy, tb33anda3rd and 3 others like this.
  4. pila38
    pila38
    It was at this point, I realized I could make it move under its own power. And when it did, I decided to put off working on the brakes again and make the steering work.
    Pulled the box out of the truck, which is a ton of fun if you’ve never done it. The column does not disconnect from the box, so all 4’ had to be leveraged and snaked around all the other components that I have already installed. And truth be told, getting it out wasn’t the hardest part, putting it back was.
    Anywho…yanked it out and removed the column bearing from the mast jacket. Then took the mast jacket off and decided where I wanted to cut it. Why am I cutting it? Because I really wanted a removable steering wheel so I needed to weld on the adapter. Figured out where the bearing needed to be relocated to further down the mast jacket, figured out where the pin mechanism needed to be welded on. And got it all put together. I am sorry though, I have almost no pics of this. I’ll get some later and post them.
    Finally I blasted some paint on the steering box and mast jacket. The jacket will get painted a different color later, so I didn’t mind when it got mauled going back into the truck.
    tb33anda3rd, swade41 and loudbang like this.
  5. pila38
    pila38
    Now, the truck can drive and steer, but she can’t stop. Guess I’m going to have to address this sooner or later.
    It was my decision to forego the standard adjustable proportioning valve. Again, you ask, why? Because I’m a glutton for punishment and also a ****er for knobs, switches, ****ons, and gauges. Growing up in Macks and Peterbilts will do that to you. So, when I saw that you could use a balance bar for your brakes and have a cool knob on your dash to adjust them with, well, I had to have it.
    There are a lot of issues to go along with this though and here they are in a nice neat list for you:
    1. A balance bar usually requires two brake master cylinders. You may have noticed by now that I don’t have two brakes master cylinders. I only have one and it’s from an International that used it as a brake MC and the clutch MC. So project one was to convert that over to a brake/brake MC.
    2. Balance bars usually have a fancy pedal ***embly for race cars that works with them. You may have noticed by now that I don’t have a fancy pedal ***embly. I have an Ansen type hanging pedal setup sold by Vern Tardel. Here’s where it gets dicey and we’ll need a sub-list:
    A. The clutch pedal does not provide enough clearance to allow the balance bar to do anything correctly. When the clutch is depressed, it hits the bar and actuates the brakes. And when trying to adjust the balance bar, it hits the upper realms of the clutch pedal. So I came up with one simple solution. Turn the pedals around. It meant having to redo a couple things on the clutch, but it gave me a ton of clearance and I kind of like the look a little better.
    It’s at this point you’re saying to yourself…this Eric guy is a *****. And you’d be correct. But I’m lovable and I made you this convenient list to prove your point for you. I could have easily just had a hydraulic clutch and ran both sets of brakes off the original setup and been done. But *****s don’t think like that and make things more complicated than necessary, so back to our list.
    B. After looking at the photos, you notice there is nothing to actually actuate the balance bar and push the pushrods into the master cylinder to make the brakes work. And, again, you would be correct. So I made three different sets of different length pushrods from 5/16”-24 bolts. I think the 3 1/2” is going to to be the ticket, so one problem solved. However, there is still nothing actually attached to the pedal that will push the balance bar in. Now I must embrace my inner hack and start fabricating something…anything.
    I acquired myself some 1/4” flat bar. Same thickness as the rest of the pedal setup. I cut and drilled a piece that will weld to the upper tube of brake pedal, so it will swing with pedal when it is pushed.
    Then, I notched a piece to fit around the bearing race for the balance bar, and that will weld to the other piece I welded to the upper tube. Pictures may help here:
    It’s a tough spot to get a good pic at night, sorry.
    This was where I left off. I need to split all the tacks and move a couple things around in order to get some better geometry, but it’s almost there. Unfortunately, I will have no time to work on it at all this week, so I’ll get back on it next week and let all two of you know how it turns out.
    And one last thing you may be wondering about is pedal ratio. I have made no mention of it up to this point. It’s because it was already kind of predetermined by the Tardel pedal setup and was a bit shy of the ideal goals. When making this new push point, it seems to be sitting higher than where the original brake yoke would connect, so I believe, if anything, it should be better.
    That was a lot, and probably not understandable, so I’ll leave you to digest that.
    LAROKE, tb33anda3rd, loudbang and 2 others like this.
  6. swade41
    swade41
    from Buffalo,NY
    All the hard work that goes unnoticed by the casual observer and also the fun of building old cars, like really building them, not just bolting things on.
    I have to say I'm envious of your driveway, a great test pad !
    nunattax and pila38 like this.
  7. GuyW
    GuyW
    If I have this straight, you were doing burnouts without any brakes?
    pila38 likes this.
  8. pila38
    pila38
    There is something about it, where you know that every nut, bolt, screw, weld, measurement, clearance was done by your own hands and brain. Even though I buy a good amount of my stuff, I usually end up cutting it up to make it what I want. The feeling of accomplishment, pride, and confidence when it finally all works together is unrivaled. Not much in the world that makes me feel better.
    And thanks, that driveway is a blessing. It’s nice to be able to rollout with no brakes, do a small burnout, and not be concerned I’m going to hit something. Looking forward to giving it the full send treatment though when I do have brakes!
  9. pila38
    pila38
    You are correct.
    nunattax likes this.
  10. pila38
    pila38
    Back from vacation. Finished up the brake pedal, still have some m***aging to do on the clutch though.
    IMG_0970.jpeg IMG_0971.jpeg IMG_0972.jpeg IMG_0973.jpeg IMG_0974.jpeg IMG_0976.jpeg IMG_0978.jpeg IMG_0979.jpeg IMG_0980.jpeg IMG_0981.jpeg
    LAROKE, tb33anda3rd, swade41 and 4 others like this.
  11. pila38
    pila38
    Pictures of the steering I promised. Not planning on rewelding the mast jacket together. I like the look of it cut down, looks racy.
    And finished the pedals tonight minus the brake light switch. Started mocking up brake lines from the MC to the line lock as well.
    LAROKE, tb33anda3rd, swade41 and 2 others like this.
  12. pila38
    pila38
    Ran some brake lines last night. The mounting holes for the line lock were a perfect match with the threaded holes in the firewall for the hood hold down. Wasn’t planning on running a hood anyway, so I saved myself the pain of drilling more holes in the firewall and mounted it there.
    Just have to fix the lines by the front crossmember that I sliced up earlier and bleed the system and we should have brakes.
    tb33anda3rd, loudbang and nunattax like this.
  13. pila38
    pila38
    Quick update: got my brake fluid, immediate found three leaks all caused by stupidity. Who’s surprised? Not me. Waiting on the correct fittings to be delivered tomorrow. Hoping to have brakes tomorrow evening.
    In the meantime, I’ve been messing around with the tuning. The Spalding Flamethrower had way too much advance coming in way too slow. (By the way there is zero parts or info on setting the curve for these things. Only the vague instructions from the 60s.). So I took it apart again and was going to change the springs and limit the advance. On further inspection, the springs were lighter than the advance kit that I bought, so I decided to just try to limit the advance and see what happens. But, finding the actual 10* limiting plate for this is umpossible. So, I welded some 1/4” flat washers onto the 15* limiting plate. Stabbed it back in and messed with it for awhile and ended up at 22* initial and 34* total, all in at 2500 rpm. There is still more I can do, but it seems to love it right now. Forgot to take pics of the washers welded on, but you can probably get the idea.
    It will not let me upload the pic prior to the washers…oh well
  14. nunattax
    nunattax
  15. pila38
    pila38
    Thanks Chris. I’ve seen that thread before, but it still left me wanting more. I guess I can’t always expect a quick easy answer! Also, my clamps came in! Of course, I screwed up the conversion, so two were too small to be used, but the larger ones fit the smaller hose perfect. So I’ll have to order another set for the lower hose. They look great though!
    tb33anda3rd, nunattax and loudbang like this.
  16. pila38
    pila38
    Here is the pic of the advance plate in the Flamethrower. Picture a flat washer welded where the advance slots are to limit movement. It works great, wish I had taken a pic.
    As I hinted at previously, I may have limited the timing a little too much, but the washers can be filed a bit larger to open up the advance if need be.
  17. pila38
    pila38
