I'm going to have to MAKE some headlight lenses...HOW?
Discussion in 'The Hokey Ass Message Board' started by Kevin Lee, Nov 14, 2003.
  1. Kevin Lee
    Kevin Lee
    Super Moderator
    I'd be happy if I could cut down a convex lens to fit this bucket but I'll most likely have to use flat glass of some sort.
    Questions:
    1) Has anyone here ever cut down a fluted lens? I don't see this working but I might get lucky.
    2) What about plain flat glass? Legal? Or pebbled like a pyrex dish to defuse the light?
    3) Any miracle plastics that I could shape with a heat gun and would stand up to the heat of a headlight bulb? Maybe some late model stuff I could pirate and reshape? It would have to have a pretty good sized sheet - like nine by twelve.
    I don't want it to look "Kustom", I want to pull off an OEM look - which will be the hard part. Maybe a blown plexi or lexan bubble with some flat fluted material behind it?
    This may not work at all. At least I have some super plain/ultra common Guides until I get this worked out or not.
  2. Tim
    Tim
    from KCMO
    try snow mobile headlights
  3. Kevin Lee
    Kevin Lee
    Super Moderator
    Nope. Not even close. These are big lights - not E&J's. I've figured something out already but I'm still trolling for ideas.
  4. Deuce Rails
    Deuce Rails
    How about looking for someone who grinds telescope lenses? Or a supply house that has low-grade convex lens blanks?
  5. Kevin Lee
    Kevin Lee
    Super Moderator
    Suppose I should add that the opening is not round - that would make things easier. It's sort of tear drop shaped. I'll try to get some pictures this weekend.
  6. Bruce Lancaster
    Bruce Lancaster
    I think you will need matched reflectors and lenses to get good results. How about making a template of what you need and doing some trolling in a big parking lot for a late model with a configuration that can be cut to fit?
    If there isn't a combination that can be adapted, widen your field of view--start eyeballing street lights and other big commercial lamps. I think most modern stuff may be lexan or something cuttable.
    I think glass lenses will not be workable--old ones will be brittle, new ones will be tempered and you will just be creating expensive gravel.
    And what have you got that a trip to Hershey won't find? Issotta-Fraschinei? Bugatti Royale? F-117 landing light? Depression ware salad bowl?
  7. manyolcars
    manyolcars
    I use a diamond blade bandsaw to cut glass. Look at the Arts and Crafts folks
  8. Rocky
    Rocky
    Classified Editor
    Some of our traffic lights have hard plastic, chrome plated reflectors that could be cut or heated into an oval shape. Some others were metal, chrome plated. You could make a mold to cast your own lenses from clear resin in any shape you wish. Be inventive!
    Hey, I just came in from the garage where I have a pair of new reflectors from old discontinued traffic lights. They measure 10.5" across and have a bulb-hole in the center about 1.25" in diameter or so....forgot to measure the hole. These are made from metal but I don't know what metal. They're chrome plated and yours if you think you might wanna cut 'em down with a sabre/jig saw. I clicked a digital photo of one but there's not enough juice in my camera batteries to conect to my computer, damn it!
    I have a pair of 36 chevy pickup lenses..convex and fluted but they're round, glass and not for sale right now.
    E-mail me if you want the reflectors, Kevin.
  9. G V Gordon
    G V Gordon
    from Enid OK
    Grim,
    A friend of mine who is Mr. Science was talking about making lenses for large telescopes with a dremel tool and carbide bit suspended on a swinging pendelum. Of course that only takes care of the concave side. Would be a butt load of work as well. Never mind, forget I mentioned it. [​IMG]
  10. Flynn's_57
    Flynn's_57
    from Nor*Cal
    Alot of NEW CAR headlights are made of PLASTIC....
    Take, for instance, the NEW beetles,
    (ugly as they are),
    Shoot, for that matter, the whole FRONT END of those things are plastic-
    As for plain (non-safety) flat glass I would say
    "what year car?"
    And then I would tell you that-
    Cops around here don't know about anything older than 1982...
    ("yea, these ARE stock lenses, officer")
    I would look at a few different headlight BULBS,
    because there must be a few out there that are "no-or-low-heat",
    Which would be a necessity for plastic headlights...
  11. Tim
    Tim
    from KCMO
    dude, do you have some of those wild ass tear drop headlights that look likr those weird horns?
  12. Kevin Lee
    Kevin Lee
    Super Moderator
    I'm not telling. I will say they are cool lights and Clark will be jealous, I'll leave it at that for now. Hahaha. I'll post a picture after they go on the car. I've got some good ideas - keep it coming.
  13. LIMEY
    LIMEY
    I put a post on here a while back trying to ID some lamps i bought that had no lenses, well they turned out to be '39 Packard & measure 9" by 16" long.....found some perfect original curved lenses & trims on Egay! there were others on there too just do a search on lenses.
    I'm using reflectors from some Bosch halogen units i picked up cheap & just smashed the lenses off, it will all go together fairly easy.
    hope that helps.
  14. Missing Link
    Missing Link
    If the lense you are trying to create is flat, you may want to check out a smaller hardware store. They can cut tempered glass as long as it is flat. Another alternative, although it is not glass, is to check out a "home improvement whorehouse." They sell flat sheets of plexi-glass that you can cut to any shape you would like. Stuff is rather easy to work with. I made a table top out of two pieces with pictures and what-not sam-iched between them. Again as long as it is something flat. You may, May, MAY be able to SLIGHTLY heat that plastic stuff from the whore house to create a contour. But I would be concerned with discoloration.
  15. Missing Link
    Missing Link
    One more thing that I just remembered, that works real well with older tail lights. Paint the buckets gloss white or silver. Believe it or not it makes a big difference. It makes a tremendous difference on a vehicle where the tail lights are not perpendicular to the road (i.e. 40 ford) Something like that may help disipation on the headlight.
  16. voneyeball
    voneyeball
    Alliance Vendor
    i'm with bruce and rocky kev, i was thinking traffic light. gotta be other applications that you could pirate along the pock marked roads of missouri...how bout those huge orange low polluting street lights.. might be something weird looking. or old billboard lighting. they cant be glass. they ARE big, could cut down... then once you figure it out, POST A GODDAMN PICTURE!
  17. Reverendcolin
    Reverendcolin
    The newly defunct Indian motorcycle had a teardrop lens (headlight) Found one pic on ebay. Not that good.
    I know they are sold aftermarket. I'll see how much and if I can get a size.
    (my spellllllling sucks
  18. 41ChevyTrucker
    41ChevyTrucker
  19. Kevin Lee
    Kevin Lee
    Super Moderator
    They're not the Indian items either. I'm out until Monday.
  20. cleatus
    cleatus
    from Sacramento
    Grim,
    I made (larger) 36 Ford dommed lenses fit my (smaller) 40 Chevy bezels by taking them to a glass shop and having them grind them down to fit using their water-cooled belt sander. They charged $15 to cut about 1/2" off the edge of the two flutted glass '36 lenses I supplied.
    Find something similar and grind down to fit?
  21. Rocky
    Rocky
    Classified Editor
    If you gotta set of these, I'll just fall down..
  22. Tim
    Tim
    from KCMO
    thats the lights i was thinkin of rocky!
  23. himmelberg
    himmelberg
    Disregarding legalities and specifications you might easily build some from 3/16 or 1/4" plex. Domed and trimmed like you know what you're doing. Start by tracing the where the flat of the lens sits under the bezel and cut that exact shape out of 1/2" plywood. Build a little box under it and drill a hole for your vacuum cleaner hose to fit. Make a frame out of plywood that will fit over the vacuum box. Clamp or screw an oversized piece of plex in the frame and "soak" it in your oven at 350F until the plex sags. This might take an hour... maybe less, depending on the type of plex. When flexible, remove from oven, place over vacuum box and suck. Control the depth of the "dome" by adding or removing vacuum. Have your helper blow cool air over the desired shape to cool. Remove from frame. Trim on bandsaw. Have another piece of plex ready to repeat. You could have two identical lenses, clear, to mount in under 3 hours with any luck. You could mask and sandblast the back for "frosting" or whatever. Good luck. himmelberg
  24. Unkl Ian
    Unkl Ian
    Were the original factory lenes flat?How about getting some glass like this cut? [​IMG]Reeded [​IMG] Fluted.
    If necessary,the edges could be beveled.You could even have it slumped if you made a mold.
  25. old beet
    old beet
    Yes, headlites can be cut down. They are just glass. Cut down easily if they have smoothe shiney side, harder if rippled. Can be ground with a wet sander. I can do it if ya can't get it done near you......OLDBEET
  26. sodbuster
    sodbuster
    from Kansas
    Kevin, If you go with plastic, check out Fantastic Plastic's across from the El Torreon. They do some real good custom stuff.
  27. Unkl Ian
    Unkl Ian
    Grimlock: You got those new lenses made yet? [​IMG]
  28. delaware george
    delaware george
    from camden, de
    i was at my buddies rod shop the other day and he was making tail light lenses...he made a metal male mold and a female ring with hole around it..he had like gridded plexi and was heating it with a heat gun and tightening bolts through the holes REAL slow like...they looked factory...would the lenses have to be curved..you could find some huge lights and cut them down
