I'm gona confess
Discussion in 'Off Topic Hot Rods & Customs' started by orangedog, Nov 1, 2025.
  1. orangedog
    orangedog
    Ok, a few months back I was having a overheating problem.
    I and a couple of friends agree I have a blown head gasket. No water in oil though.
    I took the heads off look the head gaskets over and I couldn't see where they had failed. I cleaned the heads up, reseated the valves and replaced the valve seals.
    After I clean the heads, I reinstalled them with new head bolts.
    Then I reinstalled the Intake and was getting ready to put the hoses back on. 20250616_161840.jpg
    That is a blue paper shop towel. I looked back a my pictures. The last time I had towels around the open engine was when I had installed the aluminum intake close to a year ago. That's my story and I'm sticking to it.
  2. squirrel
    moral of the story: always check the thermostat first! :)
  3. twenty8
    twenty8
    OOOPS...!!!o_O
    Look at it this way. At least the coolant was being filtered well.
  4. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Doo Doo Occurs!
  5. noboD
    noboD
    At least you were smart enough to find the problem.
  6. RodStRace
    RodStRace
    A friend was rather *backside* in his ways about keeping things covered while apart.
    Finished the freshening and fired it up late at night. Ran funny. Came in the next day and looked around carefully before diving in. Blue shop towel threads out behind the exhaust. Pulled the carb and there was no sign of the rag that he must have left in there. Ran fine after.
    orangedog likes this.
