Projects "I'm here to pick up the rubbish"
Discussion in 'Traditional Hot Rods' started by Drylake, Jul 18, 2016.
  1. Fortunateson
    Fortunateson
    Well you never know... Here in the western part of Canada driving distances tend to be long. Heck Ive driven 2-3 hours for breakfast!
  2. NoSurf
    NoSurf
    Great thread. Amazing job finding parts, and buy low sell high financing. Thanks for taking the time to post progress and pics. Roadster is looking great!
    Drylake and Outback like this.
  3. Drylake
    Drylake
    Thank you, it has been really fun, and I've met some great people!
    Thor1, Dave Mc, Dick Stevens and 2 others like this.
  4. Drylake
    Drylake
    The F1 box install is almost done. There's a little bit more to this task than I expected, but everyone I've spoken to who has done it, has said it is worth the effort. I have to make a spacer for the column drop for windshield-steering wheel clearance, shorten the steering shaft and tube, make a Tardel style shim, de-index the pitman arm lobes, machine the taper for the banjo steering wheel to fit, and adjust exhaust clearance. There's a bit in it!
    The complete steering column and box was a gift ! 20241012_151731.jpg 20241012_171632.jpg 20241012_172139.jpg
    I started with a mock up, then cut a shim out of 3/4" aluminium plate from the salvage yard.
    I put my yard sale $5 mill/drill vice to work for the first time, it's definitely not fancy, or quick, but it did the job.
  5. Drylake
    Drylake
    20250129_172806.jpg 20250131_162921.jpg 20250130_171145.jpg 20250122_161820.jpg 20250131_162921.jpg I had some time over the Christmas break to get a few things done on the roadster. Brake lines are done! The roadster has been on a couple of short maiden voyages, and I've been working out the bugs. I'm running too rich and have to make some adjustments to the carbs.
    At this stage I'm in the process of building a custom rag top using 30's hood bows I bought. I have the main structure roughed out and will chop it to suit when I get the chance.
    I've also had the time to work on the 32 coupe, which started as a $200 cowl. I made a boot skin, and put some louvres in this week.
  6. Drylake
    Drylake
    I've been playing with both 32's for a while, and the roadster has been fowling plugs. I had good results with a "penrite hpr 50" oil and things went poorly immediately once I changed out my run in oil. I switched to a "penrite shelley" 30 weight and the engine started running poorly. I've switched back to the "hpr 50" and have ordered new plugs. I have a su****ion the fuel in the tank has gone off. I had the day off work today and had great expectations of doing a lap of the block, but it wasn't meant to be unfortunately. I'm not running a hooked up charging system at the moment, I'll check battery charge, but doubt that's the issue.
    I'm running an electronic distributor (e-fire), 37 flathead, I tuned and balanced the carbys on Sunday. Got a little frustrated with it today.
    I've added a photo of the "Squint & it's mint" 32 coupe just for fun. 20250216_183730.jpg 20250215_165517.jpg
  7. NoSurf
    NoSurf
    Oil fouling or fuel fouling?
    Drylake likes this.
  8. RICH B
    RICH B
    Electronic ignitions are voltage sensitive.
  9. Drylake
    Drylake
    I've had success, I replaced the plugs, changed oil and fired it up! It coughed spluttered, blew smoke then stopped. Then I checked my fuel level, and it was empty, so I'd been ****ing up the varnish in the tank which explains a lot, haha!
    I put 20litres of fuel in, and it is now better than it ever has been, with the carbys tuned and balanced it seems much better. The brakes are at about 80 percent of where I'd like them, I've been doing shuttle runs in the yard, seating the shoes, adjusting shoes and bleeding lines, it's actually been a lot of fun ironing out the issues. 20250217_192030.jpg
    hook00pad, brEad, 4 pedals and 14 others like this.
  10. Outback
    Outback
    from NE Vic, Oz
    Good to see you moving along looking forward to catching up next time I'm over
    Drylake likes this.
  11. Mart
    Mart
    Am I missing something? Why such thick oil? 15w40 or at most 20w50 ought to be enough?
  12. Nailhead A-V8
    Nailhead A-V8
    amazing transformation.... from rubbish to rubber burner!!!
    I dig the coupe... the cowl, doors, roof bits look steel are the rear 1/4s gl***? are you planning to fill in the missing bits w metal '32 s****s? or gl*** the whole thing together? was that the frame on the roof of your suburban a couple pages back?...do you have a thread going? I love me a good "car from s****s" story!
    brEad, chryslerfan55 and Drylake like this.
  13. Drylake
    Drylake
    Hi, thanks for the kind words. The 32 ch***is rails are the ones I had on the racks of my ute. I don't have a build thread going for the coupe, it's just something I've cobbled together in the process of collecting parts for the roadster. The quarter panels that are on the coupe at the moment are gl***, the rest is steel. I have a roof section I'll be getting soon, so I can make a little more progress on the body. I have a 32 heavy axle going under the coupe in the next few days, to replace the 34 axle. The engine I have in it at the moment is a 1941 flathead, with a three speed top loader 37-39 rear, wide 5's and 40 juice brakes all round. I've louvred the 34 commercial bonnet, and made a louvred deck lid skin for the coupe. It's been fun. 20250215_165517.jpg
    brEad, treb11, Nailhead A-V8 and 8 others like this.
  14. Twin Stick
    Twin Stick
    Can’t believe someone would leave a nice body just laying around…….
  15. dirt car
    dirt car
    from nebraska
    I sometimes refer to a couple of my projects as " Dollar Cost Averaged" get a piece or part when affordable.
    Outback and Drylake like this.
  16. Drylake
    Drylake
    Well I have a charging system, ammeter, fuel gauge, temp gauges are set up for each head, lights are tested and functioning with a little more work to finish off the tail lights. Brakes need some adjustment but the roadster drives, stops and steers. I have some work to finish off on the cycle guards for rego, I'm almost there.
    hook00pad, cactus1, brEad and 19 others like this.
  17. Outback
    Outback
    from NE Vic, Oz
    How good is that, we are planning on being over there during the mid year school holidays, hopefully we can catch up & I can check it out
  18. dirt car
    dirt car
    from nebraska
    What might the paper on the door of the 5w be concealing?
    Drylake likes this.
  19. Dubonet Garage
    Dubonet Garage
    from France
    And car is now a LHD :p
  20. Drylake
    Drylake
    Photo is in selfie mode on my phone, very quick conversion
    I'm playing around with lettering.
  21. dirt car
    dirt car
    from nebraska
    Gotta have a number on the door !
    Drylake and chryslerfan55 like this.
  22. And we write our numbers backwards, just to confuse everyone.
    chryslerfan55, brEad, Drylake and 2 others like this.
  23. Outback
    Outback
    from NE Vic, Oz
    Everything iS backwards down here, well that's what we tell people :D;)
  24. Drylake
    Drylake
    My 9 year old son has just been diagnosed with bone cancer, this roadster will be put on hold for quite a while.
  25. tb33anda3rd
    tb33anda3rd
    thoughts and best wishes to you.
  26. pcbart
    pcbart
    from NC
    So sorry to hear this, prayers and thoughts for your family.
  27. NoSurf
    NoSurf
    Sorry to hear. Sending positive vibes.
    osage orange and Drylake like this.
  28. Terrible to read. All the best to your son, you and your family. Rooting for you all from Canada.
  29. The37Kid
    The37Kid
    Prayers going out to you.
    Bob
    Drylake likes this.
  30. Dubonet Garage
    Dubonet Garage
    from France
    So sorry to hear that.
    I know that words are meaningless in this situation but I send you positive vibes from France.
