I'm looking for Ideas for wire looms
Discussion in 'The Hokey Ass Message Board' started by grits, Jun 13, 2011.
  1. grits
    grits
    Yep, I did the "search", I'd like to see pictures of how you guys are doing it.
    This would be for a SBC, just want something clean and simple.
    Thanks in advance
  2. grits
    grits
    Well chit, guess I'm the only one still using plug wires, Dang!
  3. 40StudeDude
    40StudeDude
    I use 'em, rather, my Caddy engine does...but I've hidden them...consequently, pictures are hard to achieve...not much to see...
    R-
  4. HotRod31
    HotRod31
    I just use the little plastic ones 4 -3 -2 . Here is a pic, but not much to see.
    Later, Mark
  5. Here's mine buddy! Stock '55 Chevy.
    Sent from my iPhone using TJJ ****a!
  6. Not a great pic, but you get the idea...................
  7. demmals7ytriht
    demmals7ytriht
    from Speer lane
    Heres some pics of the wires I just ran on my 283, ran the wires under the headers, used the stock looms that mount aft of the block, I did use some of the cheap (under $5.00) plastic looms to keep everything ***e........
  8. flatheadpete
    flatheadpete
    from Burton, MI
    I'm gonna wrap everything in black fabric (think hockey) tape.
  9. LM14
    LM14
    from Iowa
    I use the zip tie method.
    SPark
  10. badshifter
    badshifter
    See how nobody responded to this request, but they did the second?
    We had NO idea what you were you were asking for... I for one would have never guessed plug wires from the first request..
  11. johnny bondo
    johnny bondo
    from illinois
    http://www.thehotrodcompany.com/shopnow/show_item.asp?product_id=4273, heat shrink the ends were the wire comes out. also you can make slits in the side to put one or two wires out of it if you need and then use smaller loom to run those. use the black hockey stick type tape to put them together. then use the metal hold downs to tie them to the frame or body in a nice line.
    oh i just saw you meant plug wires.... nevermind then!
  12. Chevy54
    Chevy54
    from Orange, CA
    Heres the 283 for the 51 P/U im building usin cheapo looms from JEGS I think
    Ill try to find some done similar on my 54 too
  13. Chevy54
    Chevy54
    from Orange, CA
    Heres the 383 in my 54....these style looms to me are cleam and sturdy!
    This pic isnt so great but shows the direction of wires leaving the cap..
  14. Black_Sheep
    Black_Sheep
    I don't recall who the manufacturer is but these simple vertical wire looms made for a clean looking installation...
  15. hillbilly4008
    hillbilly4008
    from Rome NY
    For wiring I like to use skate laces. Cut the ends off, then snake your primary wire through the inside of the lace. If your good you should be able to fit 4-5 16ga. wires through there. Gives it that old school cloth wrapped look, and is available in a variety of colors. For wires in high heat areas one could use the waxed laces.
    Beats the **** out of that plastic stuff.
  16. Chevy54
    Chevy54
    from Orange, CA
    Black Sheep....those look really good, nice work man!!
  17. look at all that roooommmm :eek::D.
  18. Shaggy
    Shaggy
    from Sultan, WA
    I could use a pic of cal custom tube ones on a motor if someone has one
  19. Chevy54
    Chevy54
    from Orange, CA
    Hahaha, Yeah rite! My entire lot here in Costa Mesa is the size of my old shop back in Maine!:eek:
  20. ok now your just being mean..............:D
  21. jetnow1
    jetnow1
    from CT
    The dist cap is aftermarket- it allows the wires to run that way on all small block chevys with a dist.
  22. Merlin
    Merlin
    from Inman, SC
    You could always make zip tie wire looms.
  23. 39 All Ford
    39 All Ford
    from Benton AR
    I like the little plastic screw together wire separators also, they work for me and keep thinks simple.
  24. grits
    grits
    I've never seen one like that, how does that work?
  25. Rochie
    Rochie
    Sorry but that IS a stock cap. N otice the plug wires run under and across the distributor. There are cross fire caps on the market that have connectors embedded in the plactic to acheive that look, but I would still stick with the stocker.
  26. grits
    grits
    Ok, now I'm awake, Chevy54, that's a nice looking motor, I see now how you looped the wires behind the distr. That's a very clean application.
  27. Chevy54
    Chevy54
    from Orange, CA
    Thanx Grits, this is my budget truck daily drive build...nothing but a seal kit, cleaning my *** off, aerosol spray, cheap wire looms and some new wires!!:D A much dif build then my 54!!
  28. pacificustoms
    pacificustoms
    from Napa, CA
    I went down to the fabric store and picked up some thread and laced the bunch with thread. Time consuming but very clean when done and amazingly they stay put extremely well. The wires are cloth wires from Vintage Ford.
  29. tommy
    tommy
    Wow I like that. I personally don't care for the "streetrod shelves" hanging off the side of the engine. I can see that it took some time but I like it. It could have very easily been done this way in 1956. The shelves say 90s streetrod to me.
  30. Chevy54
    Chevy54
    from Orange, CA
    ^^^ ^Now thats super clean too..Nice work!^^^^
