Technical I'm resisting temptation
Discussion in 'The Hokey Ass Message Board' started by atch, Feb 28, 2024.
  1. 60 Special
    60 Special
    from Omaha Ne.
    Those plastic ramps or "tire cradles" are all engineered to support way more weight than they are rated to support. It's like everything that supports a load, lifts a load, winches a load etc. It will always have a higher load rating than printed on the equipment. If it is made in China maybe not so, though!! Fifty years ago, I worked for a major USA store fixture manufacturer. One of my last jobs in that company was in an area called "the Model Shop". In that shop we would hand fabricate shelving with new modifications. The Engineering Department would come over and load test multiple shelves to failure, while measuring the deflection in the shelf at the same time. No way you would want a fully loaded shelving unit loaded with cans coming down on customers! The same applies to these plastic ramps/cradles. 60 Special
  2. Wanderlust
    Wanderlust
    It’s not the engineers that concern me it’s the accountants and quality control
    J. A. Miller and BamaMav like this.
  3. 05snopro440
    05snopro440
    If you're worried about that, the plastic ramps are still your better bet over the steel ones.
    Tow Truck Tom and 51504bat like this.
  4. belair
    belair
    Good. You can always die horribly later.
    05snopro440 likes this.
  5. Wanderlust
    Wanderlust
    Oh I’m not pointing at plastics in particular, I’m well aware of the generally deplorable nature of products produced for the “hobby” market, not many want to pay top dollar for something they use infrequently. We drive this problem from at least 2 directions, first by buying the cheapest item we can find and congratulating ourselves on finding a bargoon, and secondly through investment, who wants to invest in a company that looses or breaks even. We drive the race to the bottom.
    Tow Truck Tom likes this.
  6. 05snopro440
    05snopro440
    Oh definitely. All I was saying was that the cost savings and cutting qc corners typically has a more significant effect on metal products in my experience.
  7. Driver50x
    Driver50x
    I have a set of plastic ramps I have been using for about 15 years. Does the plastic deteriorate over time? Or are they still safe today?
  8. 05snopro440
    05snopro440
    Generally plastic can deteriorate in oxygen, but usually sees more significant degradation due to UV exposure or exposure to chemicals like chlorine, etc.
    As with anything, you can visually inspect them for signs you shouldn't use them such as:
    • Whitening (indicates the material has been stressed/deformed and may be compromised).
    • Crazing (fine cracking) or cracking.
    • Discolouration, changes in finish (not glossy where it was), changes in texture.
    • Signs of melting.
    • Signs of deformation.
    If you see any of the above, avoid using them. If they don't show any of the above items, I'd be confident using them.
    Driver50x likes this.
  9. jimmy six
    jimmy six
    I won’t go under without 2 different things to protect me. At minimum 6” solid wood under each tire with stops screw in. If higher needed then jack stands but the tires never leave the wood. @ 79 and using only a floor Jack the Eastwood look pretty good since you can remove the ramps.
