I'm stumped... 302 in the ranch- under load sounds like the fans hitting the shroud-
Discussion in 'The Hokey Ass Message Board' started by Tuck, Apr 8, 2012.
  1. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    OK... under load- the car sounds like the fan is hitting the shroud... or a bat cable is glancing off the fan- I couldnt find anything it could be hitting- pulled the fan. ITS STILL THERE under load.
    What in the hell could be making this noise- its been doing it for about a year- I usually don't step on the gas hard enough to hear it so....
    it sounds like its coming from up front- maybe the starter hanging up somehow? Its driving me crazy- anyone have any ideas??
    its a 302/c4 combo-
  2. budd
    budd
    i have a 350 in an OT truck, i'm thinking i have a worn exhaust lobe on the cam, it idles fine, drives ok but with the air cleaner off and i give it a quick rev it makes a cracking sound out the carb.
  3. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    yeah its not that- it seriously sounds like a cable hitting the fan- or some bolt- im gonna drop the starter right now- were just getting ready to head to Texas... pretty sure I'll be find its just annoying as hell not knowing what it is-
  4. Voodoo Trucker
    Voodoo Trucker
    Could it be the backside of the dampner touching the front cover? Mine did that years ago.
  5. DE SOTO
    DE SOTO
    I have heard that noise from a Cracked Flex plate.
    Happens ath the crank bolts ... eventually the center of the flex plate breaks out .
    Youll know what the noise was when that happens
  6. bobwop
    bobwop
    from Arley, AL
    could you be hearing pre-ignition knock? Dial back your timing a couple of degrees and/or add some high octane fuel and go for a ride. Perhaps the noise will go away.
    cheap/easy to find out.
  7. Master of None
    Master of None
    +1 had it happen to a Boss's O/t work van it sounded about like what your describing.
  8. subdajj
    subdajj
    Times 2
  9. 41hemi
    41hemi
    X3 on the cracked flexplate.....been there and done that.
  10. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    ****. OK- im on it-
  11. yup flexplates crackin around the boltholes......look at the ring gear while runnin with the cover off ...........it wobbles.....
  12. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Thanks guys- heading over to my buddy brinkers to get this fixed- hoping I can find a flex plate from one of my friends today- otherwise I'll have to wait till monday. At least we get get the old one out.
  13. Cerberus
    Cerberus
    If its not the flex plate, take a look at your motor mounts. The engine torques to one side under load or when you rev the engine. On a Chevy the engine torques to the p***enger side, probably same for a Ford. If the driver side motor mount is bad, the engine will torque to the p***enger side causing the engine to lift up, and causing the fan blade to s****e the fan shroud. Been there.
  14. brad chevy
    brad chevy
    Also check to make sure your alternator pully cooling blades are not hitting the bracket or the mounting bolts on high rev's. Had a smallblock making a noise and to isolate the problem pulled the belt and it shut up.
  15. enginenine
    enginenine
    from Loxley, AL
    The last 302 that I had that sounded like that had a worn-out thrust bearing on the crank. Under load the crank was walking forward and the torque convertor bolt were hitting the back of the block. Put a prybar behind the crank pulley and see if it walks back and forth. It should move some but not much.
  16. moefuzz
    moefuzz
    Tuck,
    In looking for a flexplate make sure you have the right imbalance,
    Due to Ford changing firing order in the mid/late 80's, the imbalance was changed as well.
    If you get a pre flexplate on a post engine (or vice versa) you will get a tremendous vibration.
    The imbalance depending on year of your engine will either be 28oz or 50 ounce, don't mix in match....
    I hope others will have more specific info....
    Also, I have heard of flexplate bolts backing out and s****ping on the inspection cover, check for loose or scared bolts and/or for a scar on the inspection cover..
    Good luck,
    moe
  17. Engine man
    Engine man
    from Wisconsin
    Can't be the fan hitting the shroud. OP says he removed the fan and the noise is still there.
  18. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    Yeah I eliminated this too pulled the fan and all the belts- and it still did it-
    It started doing it after I was at a burnout party my buddy j's.. the cracked flex plate makes a lot of sense considering how it started.
    I orig thought I busted a motor mount and figured the motor was thrusting into the shroud! The motor mount was bad- fixed it- still did it.
    SO- were ripping into it- I'll report back with our findings! I'll make sure I get the right imbalance- thank you for all the help! :)
  19. Moneymaker
    Moneymaker
    Ding, ding, ding..............I do believe we have a winner. :)
  20. HOTRODPRIMER
    HOTRODPRIMER
    This is probably the problem. HRP
  21. sunbeam
    sunbeam
    Brake torque it in reverse if it's a motor mount it won't make the noise because it will be the other mount but the flex plate will still be the same.
  22. Flex plate in the wifes chevy was cracked,could'nt hear it under acceleration but clicked loudly on the idle.
  23. bobscogin
    bobscogin
    How so? Engine doesn't know which way the trans output shaft is turning. The engine is still turning in the same direction with trans in forward or reverse. The torque reaction is the same, and always the opposite of engine rotation.
    Bob
  24. Brog
    Brog
    ...........Yep, he's absolutely right. That would be rather interesting if engines started rotating the other way just to go in reverse haha
  25. 40FordGuy
    40FordGuy
    Ditto ALL the above.
    4TTRUK
  26. titus
    titus
    If it aint the flywheel id be looking at the pinging scenario, even if it did happen after a burnout distributors have been known to move on their own! itd be really really easy to check that one off the list fast too, mark where the dist is and move it a smaall amount, like 1/16, if its a little better move it another 1/16, move it till it stops it entirely. then the timing is good.
    and the thrust problem ive heard before but it was with a stick shift car and when a person was pushing in the clutch the noise would start. so you never know.
    JEFF
  27. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yep, I've had it happen to me. The bushing fell off or broke off on the mechanical advance. No pinging sound as you would think. I check that engine in my Chevelle every which way and nothing. One day while timing it I brought up the RPMs to see how much total timing I had and Holy ****. The timing was so far off the scale in advance it was crazy.
  28. aircoup
    aircoup
    check the starter gear it may be sliding back under load i had one do that to me an that was it ''
  29. sunbeam
    sunbeam
    If you brake torque it in reverse the engine doesn't turn the other way but the drive shaft does which will torque the engine the other way and try to lift the p***enger side instead of the drivers.
  30. lexington
    lexington
    If you still dont find the problem after all the above mentioned checks look at the keyway in the front dampner.I had one break out on a sbc last summer it sounded like the fan hitting the shroud. Problem was it also ruined the crank snout.
