Technical Impala electrical grounding locations?
Discussion in 'The Hokey Ass Message Board' started by no55mad, Aug 11, 2017.
  1. no55mad
    no55mad
    Question, the 60's Impalas, where were the factory grounds located. Grounds like body to frame, motor to frame? Thanks
  2. bobss396
    bobss396
    There should be one at the back of the engine to the firewall. I've seen them at the radiator wall, between that and the voltage regulator, at one mounting screw.
  3. squirrel
    been too long to remember...was there a body ground strap at the firewall p*** side body bolt? they did have one from p*** side rear valve cover bolt to the firewall. The negative battery cable connected to the engine.
    this is from memory on a 61 impala
  4. ClayMart
    ClayMart
    I'm picturing something like a ground cable from battery negative terminal to engine block or maybe generator mounting bracket. Then a ground cable from the back of a cylinder head or a bellhousing bolt to the ch***is and maybe another to the firewall. There might be another from the frame to the core support as well. At the rear of the vehicle you might add a ground strap from the rear of the frame to the rear body panel area. These cars always seemed to have issues with flakey grounds for the tail, stop and turn signal lamps. More grounds are always better.
  5. squirrel
    More grounds aren't necessarily better. Good grounds are better. The light ground issues are usually the result of corrosion in the light sockets or housings, between layers of metal that are crimped together.
    loudbang, olscrounger and ClayMart like this.
  6. safari-wagon
    safari-wagon
    I had to add a separate ground for all my tail lights to keep the damn things lit on my 61 Imp.
    Singlefinger Speed Shop,
    still lurking around Detroit
  7. no55mad
    no55mad
    Thanks. Been having trouble with the brake lights. Using a free HF vom, in series between the supply/return wires to the brake light switch, getting a whopping 5.5 volts? Maybe the brake light sockets need a good cleaning but there are no grounds from motor to frame or body; negative battery ground mounted on the engine block.
  8. squirrel
    try adding a wire from the valve cover bolt to the firewall, or from anywhere else on the engine to anywhere else on the body.
    The brake lights go through the turn signal switch too....so many places for problems. Keep using the volt meter, it helps
  9. Truck64
    Truck64
    from Ioway
    http://www.aa1car.com/library/voltage_drop_testing.htm
    This is a super good technique and worth taking the time to understand. Works for everything, starters, charging system, lights, etc.
