impala tail lights
Discussion in 'The Hokey Ass Message Board' started by 66Rosola, Apr 3, 2010.
  1. 66Rosola
    66Rosola
    from Adel, Ia
    can I put 1965 impala tail lights on my 1966 impala with no problems
  2. Hnstray
    Hnstray
    from Quincy, IL
    I would think you would at least have to change the deck lid and rear 1/4 panel end caps........and very possibly the rear bumper. Wiring harness changes etc. Depends on if you consider that "no problems".
    Ray
  3. The Hank
    The Hank
    from CO
    Yep ,on all points. Finding an old 4 door should not be a problem and all parts should fit, Wait yours is a 4 door.
  4. jonahboo
    jonahboo
    from NJ
    sounds like a lot of work - if you are going to go thru the trouble might as well go CUSTOM - or else your car will look like a 65 with a 66 front clip
    or get a 65 and call it a day - the made about a million of 'em
  5. Retro Jim
    Retro Jim
    I have owned both at one time . Just why do you want to do that anyway ? If you like the seperate tail lights over the solid single piece then why not use 59 Caddy light ? All those Caddy lights would really be different ! How about 55 Olds tail lights ? There is a bunch of tail lights that you could make fit and would be a really nice kustom look .
    Just a thought !
    RetroJim
  6. 66Rosola
    66Rosola
    from Adel, Ia
    the reason I'm thinking 65 impala is because I thought it would be easiest. and I wouldn't have to do a lot of looking for other tail lights. And another reason I want the separate ones is because i just think it looks a lot cooler. ;)
  7. Retro Jim
    Retro Jim
    OK then , they should be a very easy swap .
    RetroJim
  8. jonahboo
    jonahboo
    from NJ
    i do not think easy as in bolt-on - there is going to be some cutting and welding - but start with acquiring a 65 deck lid first - and even that won't close shut til you do some surgery-
    good luck
