Projects IMPKO water slide decal
Discussion in 'Traditional Hot Rods' started by 36 Penny Coupe, Dec 10, 2018.
  1. 36 Penny Coupe
    36 Penny Coupe
    from VA
    I recently bought a 1950’s or 1960’s Lady Luck IMPKO vintage water slide decal. I have seen lots of information about soaking the decal and applying it. I know many people say these old ones fall apart. A chance I plan to take with my $20 investment. I really want the look of this vintage ***y lady on the quarter window of my coupe. My question is do they have adhesive on both sides? I would like to apply it face up from the back side of the gl*** for durability. Is this necessary for a car that lives in a garage? Should I simply apply it to the outside of the gl***? The directions say it can be placed on the back side of the gl***. Has anyone out there done this? Some advice would be great. You only get one shot with something like this. Thanks so much guys. [​IMG][​IMG][​IMG][​IMG]
  2. lurker mick
    lurker mick
    I have applied many old water slide decals to the inside of windows with no problems.
    I usually wet the window with a small amount of soapy water to allow the movement of the decal.
    Mick
  3. Truck64
    Truck64
    from Ioway
    Make some quality scans. Then if it doesn't work out make another one. Can't be that tough. The radio repair/restoration guys make repros for reverse decals on gl*** tuning dials. Those get destroyed when trying to clean the gl***.
  4. blowby
    blowby
    from Nicasio Ca
    That's super cool. Was going to say what Truck64 just said. You can probably even get one made on peel and stick stuff fairly easily, or do it yourself on an ink jet printer.
  5. mgtstumpy
    mgtstumpy
    I used to soak decals in a shallow bowl of water until the entire decal moves against the background and then apply to the gl***. They are fragile and can be easily damaged or tear if you're too heavy handed or try to separate decal from background too soon, before the glue has fully dissolved.
    lothiandon1940 likes this.
  6. sevenhills1952
    sevenhills1952
    I agree with truck and blowby...I would scan it first. That's a really neat decal, I'd probably keep it and use the new scanned one.
    Sent from my SM-S320VL using Tapatalk
    Pete L. and Truck64 like this.
  7. alchemy
    alchemy
    You can buy the exact same decal brand new. Buy one of those and install it, and save the original.
    Pete L., quick85 and 302GMC like this.
  8. rusty rocket
    rusty rocket
    If you go to a hobby shop that sells model cars they should have decal setting solution.
    The Shift Wizard likes this.
  9. Blue Moon Garage
    Blue Moon Garage
    You don't want setting solution. Microscale Liquid Decal Film is made for restoring decals. Just follow the directions. Most hobby shops carry it or can get it.
  10. 36 Penny Coupe
    36 Penny Coupe
    from VA
    There are some differences between this decal and most all or the reproductions I have seen. The 8 balls on her top are colored in blue most all copies are white
  11. 36 Penny Coupe
    36 Penny Coupe
    from VA
    And so are the dice in her earrings.
  12. David Gersic
    David Gersic
    from DeKalb, IL
    The glue is between the film and the backing paper. Printed that way up, you’d have to adhere it to the outside of the gl***.
    There’s no white in the image. I’d scan it, invert the image, and print it on ink jet clear decal film. Then you can adhere it to the inside of the gl***. It’ll fade eventually, but with a good image you could just print another one.
    Truck64 likes this.
  13. Truck64
    Truck64
    from Ioway
    I was going to say, if it was meant to be installed on the inside of the gl***, wouldn't it be a reverse image? Or it doesn't really matter?
  14. Truck64
    Truck64
    from Ioway
    I see a bunch of interesting decals on that auction site, they are definitely traditional. And educational, something (apparently) sorely needed today. Try to do your part.
    Surfcityrocker likes this.
  15. MikeC62
    MikeC62
    from Missouri
    Microscale.com has all the products for water slides
  16. cederholm
    cederholm
    If you have never applied a water-slide, I suggest you get some cheap ones to practice with. They aren't hard but practice wouldn't hurt. Also note, they are not UV save. The large HAMB one I have on my '53 Chevy has faded so bad that only those who know the shape will have any idea what it is.
    ~ Carl
  17. Texas57
    Texas57
    And which auction site would that be?
  18. Truck64
    Truck64
    from Ioway
    LOL, you're kidding... I hope
  19. Maicobreako
    Maicobreako
    Texas57 likes this.
  20. woodiewagon46
    woodiewagon46
    from New York
    I purchased two old travel decals from Iowa, where my car was found. After soaking the decals they literally disintegrated on the backing sheet as I tried to slide them off. I would scan it as others have suggested. How old are they?
  21. Texas57
    Texas57
    ??? no I wasn't. I ***umed an Ebay site, but was merly asking if there was a particular site he was referencing. A question Maicobreako obviously understood. Thanks Maico
  22. Chevy Gasser
    Chevy Gasser
    I would have it professionally reproduced, use the copy and save the original. Follow copyright laws. Decal restorers know what they can and can't do.
    XXL__ likes this.
  23. pastlane
    pastlane
    It's already been reproduced by at least a dozen people (myself included). Don't make life any more difficult than it has to be.
  24. 36 Penny Coupe
    36 Penny Coupe
    from VA
    Thanks to all of the great advice. After the suggestions I’m leaning towards a good quality copy and keep the original.
    pastlane and Truck64 like this.
