improve ride on 40 Ford pu ??
Discussion in 'Off Topic Hot Rods & Customs' started by putz, Nov 5, 2025.
  1. putz
    putz
    from wisc.
    I have mustang to with coil over and rear gm , ,ch***is eng, leaf spring and shocks , replace shocks ? or ?
  2. Nailhead Jason
    Nailhead Jason
    Is it too stiff? Is it too soft? Does it wallow down the road? Lots a variables and the mustang II front end doesn’t help. Tell us what it is doing. That way we can try and steer you the right direction.
    lothiandon1940 likes this.
  3. putz
    putz
    from wisc.
    the ride is stiff and rough .....
  4. Weedburner 40
    Weedburner 40
    If the rear is too stiff, try removing the shocks and drive it, this will tell if the shocks or springs are too stiff (my guess is the springs). If the front coil overs are adjustable, adjust to the softest setting and drive it. Again, it might be the springs.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
    moved to the off topic forum, Pinto IFS is strictly off topic on the main board
