Art & Inspiration In dash dwell gauge
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Mar 16, 2022.
  1. Moriarity
    Moriarity
    SUPER MODERATOR
    I copied this pic from the "save the gauges" thread. Has anyone ever seen another one of these? who made them? sure would like to find one, never knew they made em....
  2. squirrel
    never seen one, that's cool!
  3. tubman
    tubman
    Real-time monitoring of points condition; not a bad idea!
    Now I want one!
  4. J. A. Miller
    J. A. Miller
    from Central NY
    Would be handy to have on the firewall.
  5. 31Apickup
    31Apickup
    That is mine, I’ll look tonight at the back and see if it has a make. If I remember correctly the back of gauge is plastic. Got it out of a $1 pile at a swap meet.
  6. Boneyard51
    Boneyard51
    Back in the sixties, when I first became aware of hot rods and such, it seemed like people like to put more gauges in their cars. I know I liked gauges,I figured the more the better! I know in my old 430 equipped 55 Ford I had , oil , engine temp, generator, volts and transmission temp. Thought I was cool with all those gauges under my dash!
    Since I was “ gauge happy” , I looked at gauges all the time! That is where I saw my first in dash dwell meter, but never owned one!
    Bones
  7. dana barlow
    dana barlow
    from Miami Fla.
    I never saw a DWELL one as a dash gauge.
    I had a few Vac. and even a combo Vac & Boost that was stock in my Study dash< I thought that one was SUPER cool .
  8. pwschuh
    pwschuh
    The gauge is cool but I’d like to know more about what’s at the other end of the wire. How does the sensor work?
    Gasser 57, OG lil E, alanp561 and 2 others like this.
  9. Belle53
    Belle53
    I am sure it is hooked up like any other dwell meter....one wire to ground and a wire to the negative side of the coil.
    Or I could be all wrong
  10. Good way for a cheap date.
    Tell the GF ya can’t go to the movies so we’re just gonna hang at the hang out cause you’re almost out of dwell
  11. oldolds
    oldolds
    I would guess they may have been in a distributor machine of some kind. Maybe even in some off brand dwell meter. Easy enough to remove and put in a dash.
    lostmind, Beanscoot, ClayMart and 5 others like this.
  12. Bandit Billy
    Bandit Billy
    Is there an adapter so it will work with Pertronix? :rolleyes:
  13. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    @Moriarity,
    For some reason RAC sticks in my head.
    Moriarity likes this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    thems fightin words......
    grapeboy, beatnik, i7083 and 12 others like this.
  15. Do you need two gauges for dual points?
    or a toggle switch
    Rolleiflex, i7083, Rickybop and 5 others like this.
  16. tubman
    tubman
    Most distributors with dual points use the second set of points working in concert with the first set to produce a longer dwell, so there is only one total dwell. Only one gauge and no toggle switch
    NoSurf, dana barlow, alanp561 and 3 others like this.
  17. Dang it.
    i7083, Ned Ludd, Rickybop and 2 others like this.
  18. Moriarity
    Moriarity
    SUPER MODERATOR
    30 degrees per set and depending on how they are staggered on the breaker plate the total dwell is usually 36 or so degrees, so when you set them you put a pc of paper between the contacts on one set and set the other to 30, then repeat for the other set. when you take the paper out you read the total of both sets. so one dash gauge would be ok
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    the one pictured above does have an rac look... now I just gotta find one....
    hrm2k, OG lil E, dana barlow and 2 others like this.
  20. lostone
    lostone
    from kansas
    I just adjusted each set with a feeler gauge.
    Seems like I remember a distributor cap with dual point adjustment doors IF I remember correctly.
    Might have been a j.c. Whitney item.
    alanp561 likes this.
  21. Moriarity
    Moriarity
    SUPER MODERATOR
    you can use a feeler gauge, but dwell is more accurate. If it is not a GM product and doesn't have windows in the cap, you can set dwell while cranking with the cap off
  22. Bandit Billy
    Bandit Billy
    Can’t we all just get along? :cool:
    Hotrodmyk, SS327, 49ratfink and 3 others like this.
  23. Just Gary
    Just Gary
    I wouldn't *dwell* on it too much. ;):D:rolleyes:
  24. 31Apickup
    31Apickup
    There is no brand name, it does say “Made in USA” on the back and also the gauge face along with a number (model#?). There are slots in the top so it would be back lit from a light above the gauge. It had a plastic lense and metal bezel. BB804418-5DD2-48EA-B0C8-CCB4D4AA9E0B.jpeg 673E1500-C5CD-4474-B032-34B5226E4B89.jpeg E7879056-2B83-42F7-9505-619393EA83BB.jpeg
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    cool, Man I have had a saved search for "dwell gauge" on ebay since you first posted that, 2 years ago today and so far nothing....
  26. tubman
    tubman
    This is probably just a simple electric meter calibrated in a certain way to measure the dwell. We sort of got into this when we were considering making replacement control boxes for older Sun and Sterart-Warner tachometers. I'll talk to my partner about it; we can probably do it with a cheap voltmeter, a replacement face, and a resistor or two.
    alanp561, winr, OG lil E and 2 others like this.
  27. Paul
    Paul
    Editor
    You could hook up a three way switch that would cancel out one to read the other in two positions with the third showing combined
  28. I’m in.
    i7083, OG lil E and alanp561 like this.
  29. Moriarity
    Moriarity
    SUPER MODERATOR
    Found this old amp gauge and I bet it was made by the same company. Same made in USA and same light slots....
    97B08774-F7F2-4A2E-87F8-2EAB19C6ADE3.jpeg 502E8BEB-9B29-45A0-AF85-A11803DBAA35.jpeg 71D9B6EB-A4B5-4F89-B200-E39950577BB2.jpeg CDB363E3-9228-4F70-97A5-3F806D3BD797.jpeg
    Okie Pete, beatnik, akoutlaw and 3 others like this.
  30. Ebbsspeed
    Ebbsspeed
    Nope. Dual point distributors have both sets of points connected to a single terminal, so there's no way to use a 3-way switch to do what you're suggesting.
    ottoman, OG lil E and dana barlow like this.
