Technical In need of help to find 4 bar type bushings.
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Sep 18, 2023.
  1. wheeltramp brian
    wheeltramp brian
    I've got a customer's 29 ford here. And somebody had fabbed up a fourlink for the rear and used these type of bushings. I can't find anything that matches exactly. And there is a part number on this 60348 20230918_101709.jpg 20230918_101712.jpg 20230918_101727.jpg 20230918_101732.jpg . Any help would be appreciated.
    lothiandon1940 likes this.
  2. '29 Gizmo
    '29 Gizmo
    from UK
  3. wheeltramp brian
    wheeltramp brian
    I saw that link while I was looking earlier and I guess all of the Measurements are close enough and I guess these ones are just worn.
  4. '29 Gizmo
    '29 Gizmo
    from UK
    They are a press fit so dimensions are as fitted in the housing.
  5. If you have access to a lathe and you can find poly bushings a little thicker (or bushing material), you can resize or fabricate from scratch.
  6. DDDenny
    What size are the bolts?
  7. wheeltramp brian
    wheeltramp brian
    The bolts are 7/16 diameter so I don't need the Actual sleeves as I can reuse those.
  8. wheeltramp brian
    wheeltramp brian
    I got it all handled. I emailed the company that sells the bushings online. And they give me a phone number and I called them and we talked And the guy named ed really helped me out.
