SOLD _ SOLD Use for Conversion in Hot Rod or replacement of C2 Corvette: 1964 Corvette Posi IRS, virtually complete, including: Differential complete w/insulating crossmember, 3.08 gears in excellent condition; L&R Trailing arms; Rear transverse spring w/link bolts to torque arms; Center spring clamping plate; Center strut rod bracket w/camber cams; 2 strut rods; 2 half shafts; L&R lower shock mounts; Driveshaft. This is the original IRS from my 1964 Corvette, replaced with coil-over conversion. Suggest a rebuild of differential bearings, seals, posi clutches. Gears are excellent. No shipping. Pick up only. 775 233 4574 cell CALL OR MESSAGE - NO TEXTS. TEXTS WILL NOT BE RETURNED
