Technical Industrial Flathead Help
Discussion in 'Traditional Hot Rods' started by Scott67, Dec 29, 2013.
  1. Scott67
    Scott67
    from NJ
    I just aquired a early flathead powered skid pump. It was built by Maxim Motor company in M***achussets. Maxim builds fire trucks and equipment. It has 81A stamped on the cylinder heads and appears to be of the 38 to early 40s vintage. It looks to be 100% complete and is not stuck. I am going to try to get it running soon. I would like to use it in my 29 sedan project but had concerns with the bell housing pattern as I would like to run a 3 speed behind it. Will this bolt up to an automotive Trans? Any advice or info would be greatly appreciated.
  2. MBog
    MBog
    Looks like a regular old ford flattie to me...
  3. I bet it is 3 3/16 bore and relieved.
  4. cs39ford
    cs39ford
    From your photo looks like reg flatty to me Bolt up a 39 trans or adapter for what ever trans you want Should be fine
  5. Jimmy2car
    Jimmy2car
    from No. Cal
    I'm pretty sure you have a 1942 Ford engine. 221 cubic inch
  6. choptop40
    choptop40
    nice score.....
  7. Rusty O'Toole
    Rusty O'Toole
    20 odd years ago there was a guy in British Columbia making new repro 34 Ford roadsters using industrial flatheads he bought from Ford. They stopped making car and truck engines but you could still buy industrial engines.
    So yes, you can use an industrial engine in place of a car engine. I don't know what Ford did to theirs, but they may have had heavy duty bearings, pistons and valves and a very mild cam.
    The offset generator will be handy if you put on multiple carburetors.
  8. Kiwi 4d
    Kiwi 4d
    It will be a 38 to 42 ford of 221 cubes. We had an auxiliary fire pump motor which was a 39 merc , just relieved it of the fire pump and cradle bolted up the correct clutch and Pressure plate to the flywheel and fitted a stock 3 speed box. We were good to go. You should be the same.
  9. Scott67
    Scott67
    from NJ
    Excellent news. You guys are a wealth of knowledge. Thanks for everyone's input. Maybe I'll get some video of it running in the next few weeks.
  10. Once upon a time, there used to be many Industrial Ford engines around here on farm Irrigation pumps, then they started disappearing within the last 20 years or so.
