Industrial flathead
Discussion in 'Traditional Hot Rods' started by Enrico, Mar 14, 2016.
  1. Enrico
    Enrico
    Hello,
    is there any difference between an industrial 8BA flathead and a regular one? I saw an old crane at the junk yard with it. S/N *8RNN*1002* does it make sense to save it? [​IMG][​IMG][​IMG][​IMG][​IMG]
  2. choppedtudor
    choppedtudor
    same as any other...
  3. Bader2
    Bader2
    Save it if the price is decent.
  4. dan c
    dan c
    chances are it's been serviced regularly
    clem likes this.
  5. Kiwi 4d
    Kiwi 4d
    Grab the whole deal if it's a decent price and sell the crane for s**** , freebie.
    clem likes this.
  6. The nice thing about an industrial motor is that they have been run wide open all their lives, if it held together all this time its a good one.
  7. 28dreyer
    28dreyer
    from Minnesota
    Hard to tell for sure from the photo but that might be a propane carburetor on it and it may have a governor on it as well.
  8. deathrowdave
    deathrowdave
    from NKy
    Propane vaporizer for sure . Propane 105 octane . Super clean burning
  9. steinauge
    steinauge
    from 1960
    And no oil contamination or wall wear!
  10. Flatblack 31
    Flatblack 31
    I have one and it's in great shape, looks like it was well maintained. Plus someone mounted a 39' box to it![emoji57] ImageUploadedByH.A.M.B.1457997609.025293.jpg
  11. mtkawboy
    mtkawboy
    A propane motor will be spotless inside
    Denns1989 likes this.
  12. Bruce Lancaster
    Bruce Lancaster
    That's not a propane carb. That is a governor that fits between manifold and Ford carb, allowing the engine to hold a steady RPM as load changes.
  13. seb fontana
    seb fontana
    from ct
    Maybe made by HOOF..Governed engine speed to probably around max hp rpm..Have a brand new one around some wheres...
  14. Eugene Hernandez
    Eugene Hernandez
    [​IMG][​IMG]
  15. 28dreyer
    28dreyer
    from Minnesota
    Industrial engines are generally governed at a speed that produces a percentage of their max horsepower depending on their application and anticipated life.
    For instance a given engine running a typical emergency standby generator set might run at 1800 rpm which might be 65% of it's horsepower rating. The same engine used in a constant run generator set designed as a primary power supply might run at 900 rpm which might be 25% or less of it's horsepower rating to live for an extended time period.
