Technical Industrial HEMI
Discussion in 'Traditional Hot Rods' started by Model A Mark, Jan 28, 2026.
  1. Model A Mark
    Model A Mark
    from dallas
    Hey guys, Ive got this Industrial 354 with some sketchy center main caps on it.
    I cant for the life of me understand why Chrysler would do this.
    Im gonna run a 871 on it, not a dedicated "race car" but its definitely goanna take a beating now and then.
    So what do you hemi guys think ?
    Thanks ...
    tractorguy and GuyW like this.
  2. silent rick
    silent rick
    waiting for replies, never seen that before
    seb fontana and Model A Mark like this.
  3. 3blapcam
    3blapcam
    I'm not a Hemi guy, but can that block handle an 8-71?
    3blap.
  4. Doublepumper
    Doublepumper
    from OR-WA, USA
    Strange. Wonder if it was a low speed, low load setup, like an air compressor...?
    Just Gary and Kevin Ardinger like this.
  5. Adriatic Machine
    Adriatic Machine
    That’s not the best place to try and save weight.
    Possibly to fit a girdle or better yet a windage tray?
    Just Gary likes this.
  6. gimpyshotrods
    gimpyshotrods
    Yes.
  7. tubman
    tubman
    They kinda look like they are a "breakaway" design.:eek:
  8. 5w Jen
    5w Jen
    from Sweden
    It actually looks like there are extra material that could be grinded away. Like our p***enger car 354 + the extra "lumps" on the side of the bolt holes.
    Model A Mark likes this.
  9. willys36
    willys36
    My guess is a windage tray accommodation of some sort. Can't imagine the need for a girdle on huffing and grunting industrial engines. They did weird stuff with hemis. For example, they started out with a 'wet' intake manifold on 331s. Then they went to that strange thermostat crossover manifold on later engines. Also on 331s they followed Ford's lead and cast on extended bellhousings like on flathead Fords thru '53. Later engines had flat backs like most other V8s.
    On truck heads they cast on strange large bosses on the corners of the head. I have never seen these used to mount anything but I must ***ume they did at some time. Also on truck heads, they eliminated the Siameze ducts between the center exhaust ports used for manifold preheating then used engine coolant to heat the manifold and the ports are twice as tall as on p***enger car engines. To top it off they use sodium filled exhaust valves.
    Truck heads with bosses and tall heat crossover port.
    To use truck heads on p***enger engines I block the top half of the heat crossover and cur off the corner lugs. Also add new valve guides eliminating the big-stemmed sodium filled valves.
    Adriatic Machine and Just Gary like this.
  10. willys36
    willys36
    Looking at your photos it appears that the factory added material to the caps so they should be as strong as, maybe even stronger than, the p***enger car ones. Note this 331 block has screw holes to mount a windage tray whereas yours doesn't. Evidence the may have used a 'slip-on' tray on your industrial?
  11. Model A Mark
    Model A Mark
    from dallas
    That's kind of what ive been told, that you could grind them nubs off to make them look like regular stock 354 caps, not that youd want to, id think the extra material if that's what it is, would only beef it up maybe.
    5w Jen likes this.
  12. Model A Mark
    Model A Mark
    from dallas
    thats a good picture, thanks, i think yawl are correct, the caps are gonna be fine ..
