inexpensive source for rear carrier bearings?
Discussion in 'The Hokey Ass Message Board' started by wagonwheel, Apr 10, 2013.
  1. wagonwheel
    wagonwheel
    need some help with this
  2. Probably be easier if there was SOME info here? Make, model, I.D and O.D.?
  3. Hotrodbuilderny
    Hotrodbuilderny
    First try Rockauto than as Richard D suggested post more info.There are a lot of good sources out there. Google your rear and put carrier bearings in the search.
  4. bryan6902
    bryan6902
    This is one instance where 'cheaper' may not be better....
  5. Gman0046
    Gman0046
    Every time I used to buy cheap stuff it wound up costing me more in the long run. Now I buy the best.
  6. onetrickpony
    onetrickpony
    from Texas
    Cheap carrier bearings? No Way! The ring and pinion will thank you for using Timken.
  7. carmuts
    carmuts
    I have a large box of NOS Ford bearings, and another couple of boxes of other NORS bearings. What is the bearing number you need? PM me. Rod
  8. c-10 simplex
    c-10 simplex
  9. Ice man
    Ice man
    Bearings are bearings. If Timken made them they still make them. Go to a bearing place and they will match the numbers.
  10. BobMcD
    BobMcD
  11. Hotrodbuilderny
    Hotrodbuilderny
    Less expensive doesn't have to mean cheaper quality, you can go to your local auto parts and pay $20 for a 88048 Timken bearing and go to a site like Rock auto and get the same bearing, less expensive for around $8.00
  12. 226 flattie
    226 flattie
    from orange,ca
    In Southern California we have a company called bearings and drives. Sometimes they come in cheaper for the same bearing and t time they can be more costly. Check on what numbers you need and contact them or similar bearing supply co
